Re: M.T. ET Streets vs M.T. Drag radials [Re: an8sec70cuda] #475027
09/22/09 07:41 AM
09/22/09 07:41 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
Good track = radials
Marginal Track = bias ply.
At lest that's my experience. The bias ply tires push the car forward even if they spin a little, while the radials really tend to loose the traction completely if they start to spin.
Plynouth VIP '67 TT IC EFI
Re: M.T. ET Streets vs M.T. Drag radials [Re: jyrki] #475028
09/22/09 09:12 AM
09/22/09 09:12 AM
Mentor,Oh.
fattire Offline OP
fattire  Offline OP
Mentor,Oh.
I have ran any where from 15-19lbs. tried long and short burn outs, lots of water no water. Can any one me with a suspension shop in north east Ohio
Re: M.T. ET Streets vs M.T. Drag radials [Re: fattire] #475029
09/22/09 03:28 PM
09/22/09 03:28 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
i just ran 16lbs but feel i need more heat in the tirei will try longer burnouts next time.
Re: M.T. ET Streets vs M.T. Drag radials [Re: blownzoom440] #475030
09/22/09 03:50 PM
09/22/09 03:50 PM
an8sec70cuda Offline
More air pressure. CHIP
CHIP
'69 road runner, 440-6, 4 speed, Dana 60
'71 Demon 340, no drivetrain, on blocks behind the barn
'06 GMC 2500HD LBZ Duramax
Re: M.T. ET Streets vs M.T. Drag radials [Re: blownzoom440] #475031
09/22/09 03:54 PM
09/22/09 03:54 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
My car Had a B1 motor @da time when I swicht to radials, car picked up a little, ran better than with the 28 / 10" slick, go figure. No complaints here.
Re: M.T. ET Streets vs M.T. Drag radials [Re: an8sec70cuda] #475032
09/22/09 04:13 PM
09/22/09 04:13 PM
ELYRIA,OH
ELYRIA,OH
let me be more exact.i tried 19lbs the 1st pass,short burnout.very bad tire spin[2.24 60']2nd pass fair burnout and got a 1.439 60' and the 3rd pass did a short burnout and spunn real bad again but drove through it spinning the full 60' ang got a 1.88 60'.i will try more psi after some more heat with the 16lbs.
http://www.youtube.com/watch?v=dauDDvBgUz0
http://www.youtube.com/watch?v=8-Lz9ByEhiA
Re: M.T. ET Streets vs M.T. Drag radials [Re: blownzoom440] #475033
09/22/09 04:55 PM
09/22/09 04:55 PM
My duster hooks best at 15 lbs...
Re: M.T. ET Streets vs M.T. Drag radials #475034
09/22/09 04:59 PM
09/22/09 04:59 PM
Mine likes 19.5 to 20 psi. CHIP
CHIP
Re: M.T. ET Streets vs M.T. Drag radials [Re: an8sec70cuda] #475035
09/22/09 05:01 PM
09/22/09 05:01 PM
Renton Washington
Triple Threat Offline
Renton Washington
Mine are always set between 16 and 20, It will hook wherever, so I adjust rear tire pressure to adjust my reaction times.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: M.T. ET Streets vs M.T. Drag radials [Re: B1KILLER] #475036
09/22/09 06:01 PM
09/22/09 06:01 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
My car loves 16 to 19 lbs, @ 139 mph feels stable.
Re: M.T. ET Streets vs M.T. Drag radials [Re: an8sec70cuda] #475037
09/22/09 06:03 PM
09/22/09 06:03 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
same here
Re: M.T. ET Streets vs M.T. Drag radials [Re: prochargedhemi] #475038
09/22/09 06:32 PM
09/22/09 06:32 PM
Hmmm,interesting everyone seems to be running different air pressures,different body styles diferent motors big blocks small blocks..
Re: M.T. ET Streets vs M.T. Drag radials #475039
09/22/09 06:38 PM
09/22/09 06:38 PM
ELYRIA,OH
ELYRIA,OH
that was my point in asking.
i have 295/65/15 M/T ET street radial.
Re: M.T. ET Streets vs M.T. Drag radials #475040
09/22/09 06:41 PM
09/22/09 06:41 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
ET Street radials here...295/65's...best hook is 15.0 cold.
3700# Challenger 496 4600 convertor and 625#'s of torque.
Anything above the 15 and it gets dicey as to whether it'll blow the tires off 20' out.
Re: M.T. ET Streets vs M.T. Drag radials [Re: superwrench] #475041
09/22/09 07:27 PM
09/22/09 07:27 PM
Jacksonville, NC
RonP Offline
RonP  Offline
Jacksonville, NC
I run 15.5-17 (hot) in mine depending on track. 325/50-15's
Re: M.T. ET Streets vs M.T. Drag radials [Re: RonP] #475042
09/22/09 07:35 PM
09/22/09 07:35 PM
Ron, i love your car..
Re: M.T. ET Streets vs M.T. Drag radials #475043
09/22/09 09:43 PM
09/22/09 09:43 PM
Mentor,Oh.
fattire Offline OP
fattire  Offline OP
Mentor,Oh.
I'm running the same psi as you guys so I'll work on the suspension. Never made this much power so never gave it to much thought.
Re: M.T. ET Streets vs M.T. Drag radials [Re: fattire] #475044
09/22/09 09:58 PM
09/22/09 09:58 PM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
I would run my 295-65/15 MT radials down to 12 pounds.....1.30 60's...mid 5.60's at 128mph. My suspension appeared to seperate quite a bit out back with never picking up the front tires....maybe not enough weight transfer for the reason for such low psi..
65 Barracuda
All aluminum Indy HEMI with some boost!
COMING TO A TRACK NEAR YOU!
Re: M.T. ET Streets vs M.T. Drag radials [Re: instigator] #475045
09/22/09 11:35 PM
09/22/09 11:35 PM
superwrench Offline
superwrench  Offline
This is getting interesting.
I say that I hook good at around 15 cold....just that I've never tried it lower than that because it seems OK at that pressure. So many others on here running up at 18 and 20#'s that it almost made no sense to go lower.....then sit back and complain about the crappy tires!
I'm wondering if there's a little more 60' left in it if I try going down a tad more?
It hooked hard at Pinks in Seattle, and seems good at our tracks here...but there's always that search for that "little bit more".
One thing for sure though....I'll never run a bias slick again...the radials run the track so straight compared to a slick at 11#'s.
Next year I guess.....
