1/4 mile VS 1/8 setups? #474972
09/21/09 08:17 AM
09/21/09 08:17 AM
Orlando Fl
Dos Snails Offline OP
Orlando Fl
Ive noticed that Speedworld here in Orlando has gone to the 1/8 mile for the points meet. ( At least the street nats will stay 1/4mi) How does that effect your setups between the two? Or do most people leave their cars set up for the 1/4 & deal with it?
Re: 1/4 mile VS 1/8 setups? [Re: Dos Snails] #474973
09/21/09 08:21 AM
09/21/09 08:21 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I leave the same set up because I still run 1/4 also
Re: 1/4 mile VS 1/8 setups? [Re: Dos Snails] #474974
09/21/09 10:31 AM
09/21/09 10:31 AM
Texas Afghanistan Iraq etc.
DakFink Offline
DakFink  Offline
it really depends!!
If your running for points in a Bracket style. You can leave your 1/4 mile set-up and fall into what ever class / dial-in your car will run.
If your running Heads-up/Index and need to run both 1/8 & 1/4. It would be best to have a 3rd-member style rear-end and 2-3rdmembers set up 1 for each track.
I know a lot of outlaw guys that do this.
Re: 1/4 mile VS 1/8 setups? [Re: DakFink] #474975
09/21/09 12:56 PM
09/21/09 12:56 PM
Orlando Fl
Orlando Fl
I only go to the street drags to play so it is still a 1/4 mile for that. Just was wondering if you try to use all three gears through the traps in the 1/8th or optimize it for 2nd gear,ETC..
Re: 1/4 mile VS 1/8 setups? [Re: Dos Snails] #474976
09/21/09 12:58 PM
09/21/09 12:58 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Probably (depending on gear) you're gonna stay in 2nd. Most BB i've run have had auto's w/ 3.91's. The 1/8 is right about where the 2-3 shift is. I guess you'll have to run it a few times and see what works best for you.
Coming soon!!!!
Re: 1/4 mile VS 1/8 setups? [Re: Mr.Yuck] #474977
09/21/09 04:22 PM
09/21/09 04:22 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
my 1/8th mile setup is my 1/4 mile setup cut in 1/2
Re: 1/4 mile VS 1/8 setups? [Re: MegaDart] #474978
09/21/09 04:35 PM
09/21/09 04:35 PM
organ
maximum entropy Offline
organ
3/4 CAM IS THE HOT SETUP FOR 1/8 MILE
Re: 1/4 mile VS 1/8 setups? [Re: maximum entropy] #474979
09/21/09 05:09 PM
09/21/09 05:09 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
You'll need pop ups too.
Re: 1/4 mile VS 1/8 setups? [Re: MegaDart] #474980
09/21/09 05:15 PM
09/21/09 05:15 PM
Orlando Fl
Orlando Fl
That makes for a good setup doesn't it then!
