B-body intrument panel removal ???'s #471124
09/17/09 07:22 PM
09/17/09 07:22 PM
Missouri
convertriple Offline OP
super gas
super gas
Missouri
I'm trying to remove the instrument panel from a 71-74 Charger. I can't get the panel to pull out after removing all visible screws, stereo controls, etc.
Anyone know the trick to this?
Re: B-body intrument panel removal ???'s [Re: convertriple] #471125
09/17/09 08:10 PM
09/17/09 08:10 PM
Andrewh Offline
Andrewh  Offline
speedo cable and power plug
Re: B-body intrument panel removal ???'s [Re: convertriple] #471126
09/17/09 10:03 PM
09/17/09 10:03 PM
NJ
440challenger Offline
NJ
ammeter
Re: B-body intrument panel removal ???'s [Re: 440challenger] #471127
09/17/09 10:07 PM
09/17/09 10:07 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Be sure to disconect the battery.
Re: B-body intrument panel removal ???'s [Re: stumpy] #471128
09/17/09 10:32 PM
09/17/09 10:32 PM
Missouri
super gas
super gas
Missouri
some great suggestions! I did get the headlight switch, but it doesn't look good that I could forget the speedo cable
OUCH, I am getting old.
Re: B-body intrument panel removal ???'s [Re: convertriple] #471129
09/17/09 11:13 PM
09/17/09 11:13 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Remove the radio and get it out of your way. I like to drop the steering column so it's not cathing on anything.
Re: B-body intrument panel removal ???'s [Re: DaytonaTurbo] #471130
09/18/09 06:34 AM
09/18/09 06:34 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Need to drop the column.
Unhook heater-a/c cable
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: B-body intrument panel removal ???'s [Re: moparmarks] #471131
09/18/09 01:18 PM
09/18/09 01:18 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
I just did one in a '72 Satellite in the junkyard to get an a/c box. Definitely unhook the steering column, both from the support and the firewall plate. The only screws for the dash are the ones under the speaker cover and one on each side by the door hinges. Don't remove those last two, just loosen them so the dash can pivot.
Re: B-body intrument panel removal ???'s [Re: convertriple] #471132
09/18/09 05:59 PM
09/18/09 05:59 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
From the archives: Linky
John
