Re: Removal of Lower Control Arm Bushing - Any tricks ????
[Re: rocketresto]
#470836
09/17/09 07:17 PM
09/17/09 07:17 PM
Posts: 75,058 U.S.S.A.
JohnRR
U.S.S.A.
If you have acces to a press and welder, the welded washer trick works great. Most front shock washers are the correct size to weld to the shell in the control arm, don't be afraid to really cook the weld so they stay together. I use a cutoff wheel to split the sleave off the pin, with this method I can have a pair apart in less than half an hour. mike
same here , I weld in 1/2" steel flat washer , just the right size and then use a threaded rod and nut to push it out in the press , never had onenot come out , just be careful you don't weld the shell to the control arm ...
[Re: A12]
#470838
09/17/09 10:40 PM
09/17/09 10:40 PM
Posts: 21,525 N.E. OHIO, USA
A12
N.E. OHIO, USA
[Re: RaceCarRegistry]
#470839
09/17/09 10:46 PM
09/17/09 10:46 PM
Posts: 1,822 Colorado
denfireguy
Colorado
Any suggestions for removing "stuck" lower control arm bushing ?? Trying to build my 64 Savoy Wagon susp but these bushing are giving me troubles. Many Thanks, Reed in Neb.
I used the American Muscle lower control arm pivot remover. Got it from Mancini, I think. http://www.myspace.com/americanmusclellc
Worked well, not easy but still worked well. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: rocketresto]
#470840
09/17/09 11:02 PM
09/17/09 11:02 PM
Posts: 863 Pinelands , NJ
joelson6
Pinelands , NJ
IMPORTANT...........
don't just tack a couple of the sides of the washer. with that i just beat the washer off the sleeve. i had to almost weld the washer completely on the outer sleeve. worked like a charm but i wouldn't say it was as easy as pie
OH...... P.B Blaster helps too
#470842
09/18/09 02:36 AM
09/18/09 02:36 AM
Posts: 2,315 MOPAR HEADQUARTERS IN ALDEN NY
hemigod426
the best way ive found done over 50 sets, is take mopar bumber bolts 66-74 with the built in washer fits perfect size of shell, drop it in lca shell flush bolt toward t-bar hex. four tack welds then pump them right out with my otc ball joint pressed operated with impact gun. just did them in my 68 hemi charger left no marks on lca pocket, air chisel is kinda hacky, watch out for press it loads up lca flanges to much and might bent them
MOPAR OR NO CAR
[Re: A12]
#470845
09/18/09 08:46 AM
09/18/09 08:46 AM
Posts: 7,371 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
[Re: burdar]
#470846
09/18/09 08:23 PM
09/18/09 08:23 PM
Posts: 2,327 Glendale, AZ
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
I dig the inner sleeve and rubber out, then cut the outer with a torch. Does no damage to the arm if youre good with a torch. I have them down to about 10 minutes per bushing.
1969 Nova 454/M21/3.31 Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD 5.0/4R70W/3.55 (Daily driver)
[Re: 74fish]
#470848
09/20/09 02:58 AM
09/20/09 02:58 AM
Posts: 4,152 SO. CAL.
70blackfish
SO. CAL.
I use the washer and press but I put the washer inside after digging the rubber out. You can also use a torch to burn the rubber out. Works great.
thats the way i do it too///light the rubber on fire
