Page 2 of 3 1 2 3
Re: B-1 PSO Dyno Test [Re: Diablo] #468861
09/15/09 05:23 PM
09/15/09 05:23 PM
SE Michigan
TS3303 Offline
TS3303  Offline
SE Michigan
nice work Pete. motor looks good and Marcella makes some good looking manifolds.
Re: B-1 PSO Dyno Test [Re: jim sciortino] #468862
09/15/09 06:03 PM
09/15/09 06:03 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Pick up 20 and you'll be right around 1200.
Awesome power for a straight head. I wonder what it would do with one of your new castings in a full max N/A effort???
Are you going to fix the dyno and run it again up to 8500 or so??? And is the A/F lean or is it just me???
You wouldnt call this a max effort N/A effort?
Good numbers, nice going Pete..
Bob Coomer from Ky
I've seen engines with 17+ compression, well over an inch lift and ring stacks from hell, insanely light cranks and bob weights, among other "tricks". I don't know whats in this engine other than whats listed and whats listed in not on kill. Plus he said the newer PSO head is a better deal....so no, I wouldn't call this max effort.
Killer, but not an "on the edge" deal.
Would youc call it a max build???
I would say its a good effort. I would imagine the engine has a good nice ring pack, and the parts are pretty light, titanium valves, aluminum rods etc, sheet metal custom intake...
I would say yes..pretty good effort imo.
Sure diff heads, diff cam, diff pistons might more power..but it would be the same engine then either.
Sure it would be easy to spend another $10-$15K on the same engine..for what 5-10% increase in power maybe?
Re: B-1 PSO Dyno Test [Re: Bob_Coomer] #468863
09/15/09 09:07 PM
09/15/09 09:07 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
Way to go Best Machine Racing Engines!!!
I have been dying to see a set of these heads in action!!! Very nice #'s!!
Can't wait to see the #'s at the track in the car!!!
Re: B-1 PSO Dyno Test [Re: cl440] #468864
09/15/09 09:25 PM
09/15/09 09:25 PM
Smyrna, South Carolina
STEFF Online content
STEFF  Online Content
Congrats Pete!!! Looks awesome & killer power!!! Chuck told me you made some nice power. Is the Avenger going to see the track any time soon? Stab that motor in there & go!!!!!!
Re: B-1 PSO Dyno Test [Re: Bob_Coomer] #468865
09/15/09 09:36 PM
09/15/09 09:36 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
Bob Coomer from Ky
I agree...
Its just that I have a chevy/ford complex.
Those cats don't start talking about a serious effort until every last part is messaged to within an inch of its life and nothing goes in unless its state of the art and on the edge of destruction.
This engine makes real steam in a reasonable RPM range and should be fairly reliable. A nice overall package and mighty fine looking.
Re: B-1 PSO Dyno Test [Re: jim sciortino] #468866
09/15/09 09:54 PM
09/15/09 09:54 PM
Mission BC
10sec440 Offline
10sec440  Offline
Mission BC
Really nice, good job. Why don't you send it to me, I will try it out and send it back to you.
Re: B-1 PSO Dyno Test [Re: 10sec440] #468867
09/15/09 11:39 PM
09/15/09 11:39 PM
SouthEast Michigan
P
PETE@BESTMACHINE Offline OP
P
SouthEast Michigan
Thanks guys, I will try to answer your questions. Yes we sell the valve covers, the engine is close to a max effort for what it is, light crank and bob weight for a 588, trick ring pack and intake. If I did it all over there would be some changes for sure. Its going in the car next and I will tune it from there. For a 588 I don't think a TS or Predator is much better. I now wish I had used the 4.75 crank I have, but it would not fit with the 55mm cam. The heads flow 476 Intake and 330 Exhaust on our bench. We never touched the carbs, every pull the the break was moving a little and the vac. was going up as the rings were seating. Was not cheap to build and there was a lot of fab work for sure, but none of them are at this level. I changed the dry sump pulley already to lower the oil pressure also. Here is a picture of the car. Thanks again!
Re: B-1 PSO Dyno Test [Re: PETE@BESTMACHINE] #468868
09/15/09 11:46 PM
09/15/09 11:46 PM
SouthEast Michigan
P
P
SouthEast Michigan
More pictures
Re: B-1 PSO Dyno Test [Re: PETE@BESTMACHINE] #468869
09/16/09 12:53 AM
09/16/09 12:53 AM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
Hello,
Super job!!
Yea, what about those A/F numbers?
Damon
Re: B-1 PSO Dyno Test [Re: mopardamo] #468870
09/16/09 01:35 AM
09/16/09 01:35 AM
land of the free
ts racer Offline
ts racer  Offline
land of the free
anybody have contact info for john marcella?
Re: B-1 PSO Dyno Test [Re: ts racer] #468871
09/16/09 07:01 AM
09/16/09 07:01 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Very, very nice Pete.
Re: B-1 PSO Dyno Test [Re: PETE@BESTMACHINE] #468872
09/16/09 07:15 AM
09/16/09 07:15 AM
St. Clair Shores, Michigan
bigsbigelow Offline
bigsbigelow  Offline
Pete, what class are you going to be running the Avenger in?
Ryan "Bigs" '73 Duster (BLKDUST) - Black, 100% factory sheet metal, flat hood, 346 cid, J Heads, and a bench seat. http://s268.photobucket.com/albums/jj1/bigsbigelow/ Best to date: 12.40 @ 109 mph
Re: B-1 PSO Dyno Test [Re: bigsbigelow] #468873
09/16/09 08:12 AM
09/16/09 08:12 AM
SouthEast Michigan
P
P
SouthEast Michigan
John Marcella/Marcella Manifolds 248-259-6696. Hope to run Top Sportsman if its fast enough,may have to spray it, Time will tell. The VBSFC show its a little fat yet, but the rings are not fully seated and the Dyno had problems. Will tune the rest of the way in the car.
Re: B-1 PSO Dyno Test [Re: PETE@BESTMACHINE] #468874
09/16/09 08:27 AM
09/16/09 08:27 AM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
good luck with it, that is going to be a GREAT looking ride and I bet fast as well. Should be plenty quick enough to run T/S. I'm betting that car goes 7.40's or even quicker off the trailer...
Re: B-1 PSO Dyno Test [Re: PETE@BESTMACHINE] #468875
09/16/09 09:12 AM
09/16/09 09:12 AM
detroit area
moderncylinder Offline
detroit area
that manifold was built really by et performance when john worked there wasnt it? i remember talking to pete about it and how much work it was,, a buddy of mine worked at et and told me they had well over 60 hours in it,, had 40 hours in machining the runners,, you might not beable to see it from the pics but each "pair" of runners is made out of billet,, ie, runners 1,1nd 3 are one piece transitioning and ovalish port opening into a round opening in the plenum. very nice work to say the least,, i doubt john would do that today since he has no cnc machine though cary could machine them up but id have to say that would be a 5k manifold,, im sure john would just use a folded runner like all his other stuff.
nice job on the power pete,, generally you are limited to about 2.4hp per cfm of airflow with a motor like yours,, to make 1200 hp you would need 500cfm,, so you maxed out those heads im sure. 1200hp in that car 2300-2400lbs?? shouldnt that be a 7.20 or so? good job
Re: B-1 PSO Dyno Test [Re: moderncylinder] #468876
09/17/09 12:30 AM
09/17/09 12:30 AM
SouthEast Michigan
P
P
SouthEast Michigan
Thanks Jeff, yes it was built at ET Performance and Cary and John built it. It is trick for sure and I wasn`t sure how well it would work on the engine. ET also worked on the Heads a lot also. We used mine as a start for the new ones with improvments. Someone like yourself could work on the new ones and pick them up, they are not maxed out. 7.20`s would be cool but frist things frist, hope to have it in the car by the weekend.
Re: B-1 PSO Dyno Test [Re: PETE@BESTMACHINE] #468877
10/11/09 08:02 PM
10/11/09 08:02 PM
SouthEast Michigan
P
P
SouthEast Michigan
Finally installed the Engine and finished all the fun with a new install. Its going to the chassis shop for a new hood scoop, front end alignment, 4-link adjustment if nessary and scale for correct corner weights. I am trying to sill get it out this year.
Re: B-1 PSO Dyno Test [Re: PETE@BESTMACHINE] #468878
10/11/09 08:22 PM
10/11/09 08:22 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Looks great Pete, make sure you update us when you make some laps!
Re: B-1 PSO Dyno Test [Re: Bigcube] #468879
10/11/09 09:05 PM
10/11/09 09:05 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
A friend of mine recently bought a set, to see the work that he puts into the heads and intake in person, is to really appreciate.
Re: B-1 PSO Dyno Test [Re: B1KILLER] #468880
10/11/09 09:17 PM
10/11/09 09:17 PM
Looks Awesome Pete!!
Page 2 of 3 1 2 3
