Re: Leaf Spring relocation pics? [Re: Ron Silva] #468530
09/16/09 12:05 AM
09/16/09 12:05 AM
Stow ,Ohio
demon440 Offline
demon440  Offline
Stow ,Ohio
My junk
Re: Leaf Spring relocation pics? [Re: demon440] #468531
09/16/09 12:07 AM
09/16/09 12:07 AM
Stow ,Ohio
demon440 Offline
demon440  Offline
Stow ,Ohio
Before assembly
Re: Leaf Spring relocation pics? [Re: chargermop] #468532
09/16/09 05:21 AM
09/16/09 05:21 AM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
last one of the back. I have also lowered the car 2" ....
How close is the pass side spring to the gas tank?
Re: Leaf Spring relocation pics? [Re: Ron Silva] #468533
09/16/09 09:16 AM
09/16/09 09:16 AM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
67 Valiant, minitubbed and springs relocated into the frame with a Mopar kit. I used a steel rod to keep everything square until it was all tacked in place. Then you have to CUT the rod to get it out!
Nice work Wish I could get you to help me with my 66
Re: Leaf Spring relocation pics? [Re: Scamp408] #468534
09/16/09 09:59 AM
09/16/09 09:59 AM
Indy
FlyFish Offline
FlyFish  Offline
Indy
I know with mine I had to "massage" the gas tank with a fix anything tool to make the passenger side spring fit.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: Leaf Spring relocation pics? [Re: Ron Silva] #468535
09/16/09 10:49 AM
09/16/09 10:49 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
When I relocated my front spring hangers, I was not satisfied with the inside unsupported hanger, and I added a gusset seen in the attached pic. Just a thought.
Re: Leaf Spring relocation pics? [Re: LA360] #468536
09/16/09 10:55 AM
09/16/09 10:55 AM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
If you are running a fuel cell I don't think there's an issue as to whether you mount the box on the outer or inner wall of the stock frame rail. But if you are running a stock tank, I think you need to mount the box so its flush with the inner wall of the frame rail, otherwise you may have clearance issues between the leaf spring and the sides of the gas tank.
Re: Leaf Spring relocation pics? [Re: Sixpak] #468537
09/16/09 02:47 PM
09/16/09 02:47 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
Looks tight to me
Re: Leaf Spring relocation pics? [Re: Scamp408] #468538
09/16/09 06:14 PM
09/16/09 06:14 PM
Melbourne , Australia
LA360 Offline OP
LA360  Offline OP
I have seen instances where people will shorten the tank to clear the leaf spring.
AL....
Alan Jones
Re: Leaf Spring relocation pics? [Re: Ron Silva] #468539
09/16/09 06:33 PM
09/16/09 06:33 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
that is a great way to do it!
Re: Leaf Spring relocation pics? [Re: LA360] #468540
09/16/09 07:46 PM
09/16/09 07:46 PM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
AL....
No, I spaced mine right in the middle, equal on each side, and never had any problems with the spring being to close to the tank. It never hit at all. I have went to a cell now though, not for that reason though. I figured that 9.80s on a stock tank was good but if something happen it wouldn't be good..
Re: Leaf Spring relocation pics? [Re: 70dusterjohn] #468541
09/18/09 08:59 PM
09/18/09 08:59 PM
LA360 Offline OP
LA360  Offline OP
I know in my case, the factory tank isn't an issue as I will be running a fuel cell.
What plate thickness is used for the spring boxes?
AL.....
Alan Jones
Re: Leaf Spring relocation pics? [Re: LA360] #468542
09/19/09 09:40 PM
09/19/09 09:40 PM
LA360 Offline OP
LA360  Offline OP
Alan Jones
Re: Leaf Spring relocation pics? [Re: LA360] #468543
09/20/09 08:24 AM
09/20/09 08:24 AM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
I have a new tank in the car now so I just wanted to make sure it would be ok.Looks like its gonna be close.I want to get the tubs done so I can get the interior back in.
