Re: Anyone run late main brgs in and early block? 360 SB
[Re: goldmember]
#466388
09/12/09 02:40 PM
09/12/09 02:40 PM
Posts: 1,880 USA
Ron Silva
USA
I thought the width of the thust flange to flange was slightly different? Like .004 Not sure. But you should check the thrust clearance real close and see what you have. It may be too much or too little. Factory spec is .002 to .007 with max allowable being .010
SRT DEMON ONE SEAT
[Re: dartman366]
#466391
09/12/09 05:39 PM
09/12/09 05:39 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
I don't know about 360's but I suspect the differance is the same as early vs late big block bearings & this photo should explain the change... Thanks to Brandon @ 440 Source for the photo... Bearing width & diameter are the same, it's the thrust face diameter that is larger...
[Re: goldmember]
#466394
09/12/09 09:53 PM
09/12/09 09:53 PM
Posts: 75,066 U.S.S.A.
JohnRR
U.S.S.A.
Right. The late(wide) thrust bearing fit's well inside the relief area in the block and cap. Therefore my question.
If the bearing fits and the crank spins then you don't have an issue , on a big block there is no way you would get the large thrust bearing in an early block as the picture above shows .
[Re: goldmember]
#466395
09/12/09 10:10 PM
09/12/09 10:10 PM
what are the actual part #'s of the bearings your looking at?
[Re: goldmember]
#466397
09/12/09 10:25 PM
09/12/09 10:25 PM
i like the 4948MA bearing better. either should work fine. it just depends on if you want 1/2 or 3/4 groove
#466400
09/12/09 10:44 PM
09/12/09 10:44 PM
Posts: 4,501 Gainesville,FL
goldmember
Gainesville,FL
I'm not worried about a 3/4 groove on this deal,it's not mine and it won't make enough power or rpm to be a threat to itself.Thanks
