Page 2 of 3 1 2 3
Re: Holes in cowl hood [Re: FASTFISH420] #466068
09/11/09 10:26 PM
09/11/09 10:26 PM
Cairns Queensland Australia. T...
V
vc360 Offline
vc360  Offline
V
Carbs are way to close to the top of the hood..you have to have atleast 1 inch over the vent tubes..2 inch is more like it..put you a nice looking aero scoop on it...I bet it would pick up 2 tenths..
I agree carbs are too close.
Re: Holes in cowl hood [Re: vc360] #466069
09/11/09 10:28 PM
09/11/09 10:28 PM
Salina ks
572_dup2 Offline OP
Back On The Bumper!!
572_dup2  Offline OP
Salina ks
Yes carbs are too close. What are the options for a hood? Nothing against the guys that have the hemi type scoops but is there something different?
Shawn Jennings
Re: Holes in cowl hood [Re: 572_dup2] #466070
09/11/09 10:31 PM
09/11/09 10:31 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
Show me a pic of the hood an scoop it needs.
Have you ever seen the clear plexiglass scoops? I think RT540 had one and I saw cars in Orland with them. They don't detract from the car or hood since they are clear. They have a good size opening too.
No?
1.39 9.85 - 137 mph
Re: Holes in cowl hood [Re: Ari440] #466071
09/11/09 10:32 PM
09/11/09 10:32 PM
Salina ks
572_dup2 Offline OP
572_dup2  Offline OP
Salina ks
YA thats wild!
Shawn Jennings
Re: Holes in cowl hood [Re: 572_dup2] #466072
09/11/09 10:33 PM
09/11/09 10:33 PM
Central,Ohio
FASTFISH420 Offline
FASTFISH420  Offline
Central,Ohio
Did you have air cleaners on it?You have to have a flat hood with the carbs popping up thru and put the air cleaners on it..you will have to much turbulance without the air cleaners..
Think about it..you have a big motor with big carbs and a big intake..needs alot of air to get it moving..
It probably goes 600 feet and quits pulling..been there done that...cowl hood take alot of R/D to get to work...
1969 Barracuda 8 second all/motor small block 2014 Shelby GT500 Mustang Uratchko Racing Engines www.URE-RACING.com
Re: Holes in cowl hood [Re: 572_dup2] #466073
09/11/09 10:33 PM
09/11/09 10:33 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
I feel your pain when it comes to hoods/scoops, etc
To stay under my hood, I can't run a spacer and I use a dropped base air cleaner so it don't suck a rock in and all that means is can't get it to work right and throttle will not go to WOT and yes we tried some things and not done yet but it slows the car down
If you want it to look like a certain era and use certain parts, it limits you .
I highly doubt that if the old guys could of went super fast without altering wheelbase and 100 other things they did they would of , we look back and now it looks cool but, then I'm sure there were people that didn't like to do it
I do agree on the bigger, pro style scoop for getting those carbs in clean air but, that should not cause it to backfire not start ,etc
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Holes in cowl hood [Re: 572_dup2] #466074
09/11/09 10:34 PM
09/11/09 10:34 PM
Wisconsin
Garceau Offline
Garceau  Offline
Wisconsin
Cars with the hoods off generally will slow down. Thats bucking alot of wind into that firewall etc.
Re: Holes in cowl hood [Re: Garceau] #466075
09/11/09 10:38 PM
09/11/09 10:38 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
hhmmm, i never run a hood
Re: Holes in cowl hood [Re: FASTFISH420] #466076
09/11/09 10:41 PM
09/11/09 10:41 PM
Salina ks
572_dup2 Offline OP
572_dup2  Offline OP
Salina ks
I no dont have any air cleaners on it.
Shawn Jennings
Re: Holes in cowl hood [Re: sixpackgut] #466077
09/11/09 10:44 PM
09/11/09 10:44 PM
Wisconsin
Garceau Offline
Garceau  Offline
Wisconsin
Should try one, think about the wind just hitting that firewall. Your like going through the air with a 2x6 piece of plywood on the front end. I realize an open grill lets some air in there anyways, but this also creates alot of turbulence. I took my steel hood off my dart, figured being lighter would pick me up some. It fell off a bunch. Put hood back on, same day, picked right back up.
Re: Holes in cowl hood [Re: Garceau] #466078
09/11/09 11:03 PM
09/11/09 11:03 PM
sc
tjmarcus1 Online content
tjmarcus1  Online Content
sc
as i said in your other post, i know a little about t/r's.when you get a scoop, make sure the opening is large enough. and make sure you position it correctly. the more clearance you have on top of the carbs, the better you are. lastly, seal the carbs., at least put a pan on the carbs to reduce turbulence.
Re: Holes in cowl hood [Re: 572_dup2] #466079
09/11/09 11:07 PM
09/11/09 11:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
No?
Is the back of the cowl scoop open... if so close it
off with a piece of plexiglass or lexan.... if the air
is coming in the front it can go straight through
and create a suction on the carbs.... if they are
close to the top get more clearance.... I like 2"
minimum... more is better... and the string from
the front of the hood to the roof line works(opening
needs to be above that line)
EDIT
You might want to phase the dist also... that could
be the back fire issue
Re: Holes in cowl hood [Re: MR_P_BODY] #466080
09/12/09 07:50 AM
09/12/09 07:50 AM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
Fuel injection with twin 4-brrel throttle bodies....all problems solved!.....and use same hood.
65 Barracuda
All aluminum Indy HEMI with some boost!
COMING TO A TRACK NEAR YOU!
Re: Holes in cowl hood [Re: FASTFISH420] #466081
09/12/09 01:04 PM
09/12/09 01:04 PM
Salina ks
572_dup2 Offline OP
572_dup2  Offline OP
Salina ks
This car fly's...
What scoop is this?
Shawn Jennings
Re: Holes in cowl hood [Re: 572_dup2] #466082
09/12/09 01:06 PM
09/12/09 01:06 PM
Dearborn Hts, MI
Sledge_57 Offline
Sledge_57  Offline
Dearborn Hts, MI
This car fly's...
What scoop is this?
Kinda looks like what Eddie did Shawn, aero scoop grafted to a cowl
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker
Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
Re: Holes in cowl hood [Re: Sledge_57] #466083
09/12/09 01:08 PM
09/12/09 01:08 PM
Hemiroid Offline
Hemiroid  Offline
This car fly's...
What scoop is this?
Yep, that's what it is. The manifold and carb was too high for the cowl so they added the scoop on top.
Re: Holes in cowl hood [Re: Sledge_57] #466084
09/12/09 01:08 PM
09/12/09 01:08 PM
Salina ks
572_dup2 Offline OP
572_dup2  Offline OP
Salina ks
I kinda like that!
Shawn Jennings
Re: Holes in cowl hood [Re: 572_dup2] #466085
09/12/09 01:14 PM
09/12/09 01:14 PM
Salina ks
572_dup2 Offline OP
572_dup2  Offline OP
Salina ks
maybe this?
Shawn Jennings
Re: Holes in cowl hood [Re: Bigcube] #466086
09/12/09 02:17 PM
09/12/09 02:17 PM
North Sweden
RT540 Offline
RT540  Offline
North Sweden
Re: Holes in cowl hood [Re: sixpackgut] #466087
09/12/09 03:49 PM
09/12/09 03:49 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
I feel your pain, my scoop looks like I'm trying to catch something other than air. My Older hood scoop didn't have enough clearance, you could actually see the scoop getting sucked in, like the carb wanted to eat it.
Page 2 of 3 1 2 3
