Re: total piece of trash!!!!!!!!!!!!!!!!!!
[Re: tjmarcus1]
#465924
09/11/09 09:54 PM
09/11/09 09:54 PM
Posts: 4,055 Salina ks
572_dup2
Back On The Bumper!!
Salina ks
I need to show the pic of the hood now. See what you think. It has holes in it but rab just the same?
Shawn Jennings
[Re: 572_dup2]
#465925
09/11/09 10:01 PM
09/11/09 10:01 PM
Posts: 636 Central,Ohio
FASTFISH420
Central,Ohio
How do the plugs look? they should look like brand new with q-16..what kind of timing?have you dynoed it with the new set-up?
A cowl hood will not work..trust me. I have gone down that road.you might try to run with the hood off and put 2 big K/N air filters on it..having the 2x4 is going to be a challenge there.. do like the truck pullers do..it will look goofy,but worth a try..
1969 Barracuda 8 second all/motor small block
2014 Shelby GT500 Mustang
Uratchko Racing Engines
www.URE-RACING.com
[Re: sixpackgut]
#465926
09/11/09 10:13 PM
09/11/09 10:13 PM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
Fill them with fuel, take them off the intake and set them on the workbench for 20 mins and see if they are dripping. My old carb did that.
bigcube, where were they dripping from? the boosters, intermediat circuit? PV vac hole?
I don't know, only one barrel in the secondaries. I never did figure it out. The butterflies weren't wet so seems like it was from below that.. the transfer slots maybe? The carb was strange, needed HUGE jets. It needed 99 sq when my other 1150 needed 92 on the same motor.
[Re: Bigcube]
#465927
09/11/09 10:28 PM
09/11/09 10:28 PM
Posts: 2,813 Blue Ridge, VA
Plumb Wired
Blue Ridge, VA
Where do you have the air gap set on the crank trigger pick up?
Mike Gray
RIP Monte Smith
aka: OutlawFish '98 Bickel Dodge Dakota PST
[Re: Plumb Wired]
#465928
09/11/09 10:29 PM
09/11/09 10:29 PM
572_dup2
Salina ks
Dont quote me on this but i think its around 60?
Shawn Jennings
[Re: 572_dup2]
#465929
09/11/09 10:37 PM
09/11/09 10:37 PM
Plumb Wired
Blue Ridge, VA
We had a problem with the car not starting when it was just recently run with no changes, air gap was .060 - .065. After checking everything known to man we tightened up the air gap to .040 and it hasn't missed a beat since.
Mike Gray
RIP Monte Smith
[Re: 572_dup2]
#465931
09/11/09 10:49 PM
09/11/09 10:49 PM
Plumb Wired
Blue Ridge, VA
Can't explain that. Just thought I'd add our recent odd experience. There is no need to replace a pick if it has between 80-85 Ohms. Could be numerous things, kinda hard to trouble shoot if you're not there. I'm sure one of the rocket-surgeons on here will figure it out.
Mike Gray
RIP Monte Smith
[Re: 493_DART]
#465934
09/11/09 11:00 PM
09/11/09 11:00 PM
FASTFISH420
Central,Ohio
Mike, I thought you were going to tell him to put a 114mm turbo on it..LOL A F3R procharger would love that cubic inch...
www.URE-RACING.com
[Re: dizuster]
#465937
09/12/09 09:28 AM
09/12/09 09:28 AM
Posts: 6,314 The Swamp
MegaDart
The Swamp
I'm certainly no rocket surgeon but check to make sure your plug wires aren't crossed. who set up your carbs for Q16?? without a dyno that fuel is very hard to tune good luck
[Re: MegaDart]
#465938
09/12/09 09:36 AM
09/12/09 09:36 AM
Posts: 1,090 north cakalaky
instigator
north cakalaky
Twin dominator throttle bodies with electronic fuel injection....would be the [Edited by Moparts - Family Friendly Site - Keep it clean]....but I already posted that in his other thread...If you like spending money that would be a good way.
65 Barracuda All aluminum Indy HEMI with some boost! COMING TO A TRACK NEAR YOU!
[Re: MegaDart]
#465939
09/12/09 10:04 AM
09/12/09 10:04 AM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
good luck
I'm defnately no expert but have you always run the q16? If so,try another fuel.I run VP fuels and love it,but I went to their 113 wich isn't as oxygenated as the q16 and had nothing but problems.You can't just jet it up like they ell you,you need to richen up the idle and intermediale circuits as well.Just a thought.
