moparts, i need some help #465357
09/10/09 11:58 PM
09/10/09 11:58 PM
Eagleville Tn.
rtstreet Offline OP
rtstreet  Offline OP
Eagleville Tn.
need to find a crank with theese specs::
4.050 stroke
440 mains
2.200 rod
mopar rod width
6 or 8 bolt
cell is 615 573 2738, thanks
Re: moparts, i need some help [Re: rtstreet] #465358
09/11/09 12:08 AM
09/11/09 12:08 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Can one offset grind a 4.15 stroke crank to have less stroke? I dont see why not, moving the pin up or down should matter.
Re: moparts, i need some help [Re: Bob_Coomer] #465359
09/11/09 12:15 AM
09/11/09 12:15 AM
Eagleville Tn.
rtstreet Offline OP
rtstreet  Offline OP
Eagleville Tn.
have to cut to much, most but not all 4.15 cranks have the rod hole to close to the out side, but i think we can up stroke a 3.9? crank. thanks for posting so quick
Re: moparts, i need some help [Re: rtstreet] #465360
09/11/09 10:18 AM
09/11/09 10:18 AM
Cab_Burge Online work
Cab_Burge  Online Work
Contact Ohio Crankshaft company for the one you want made, they have unfinished cores sitting on the floor waiting to be ground usually
Re: moparts, i need some help [Re: rtstreet] #465361
09/11/09 01:04 PM
09/11/09 01:04 PM
Man i'm still looking around and ain't having much luck. But i will keep in touch.
Re: moparts, i need some help #465362
09/11/09 06:33 PM
09/11/09 06:33 PM
Eagleville Tn.
rtstreet Offline OP
rtstreet  Offline OP
Eagleville Tn.
thanks guys, i know will find something.
Re: moparts, i need some help [Re: rtstreet] #465363
09/11/09 11:26 PM
09/11/09 11:26 PM
Eagleville Tn.
rtstreet Offline OP
rtstreet  Offline OP
Eagleville Tn.
anyone make a crank with 3.91 stroke and a chry rod journal?
Re: moparts, i need some help [Re: rtstreet] #465364
09/11/09 11:35 PM
09/11/09 11:35 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Dang
About a week ago, I ran across a Hemi crank with standard chrysler rod pin that was a 4.0 stroke crank. I been looking for the last few minutes, but cant find or remember were I saw it at....
I will looks some more tomorrow...wife's hollaring at me to come to bed...
Re: moparts, i need some help [Re: Bob_Coomer] #465365
09/12/09 12:10 AM
09/12/09 12:10 AM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
I have a cracked 4" one with std Chrysler journal but I don't think you want that. Good luck, hope you find one.
Re: moparts, i need some help [Re: Bigcube] #465366
09/12/09 12:20 AM
09/12/09 12:20 AM
Eagleville Tn.
rtstreet Offline OP
rtstreet  Offline OP
Eagleville Tn.
what brand was it, or was it custom?
Re: moparts, i need some help [Re: rtstreet] #465367
09/12/09 12:26 AM
09/12/09 12:26 AM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
It was a welded stock forged crank. I had Crankshaft specialist do the work back in the late 80's. It was before all the cheap aftermarket cranks were available. I honestly don't remember if the crack was on a main or a rod journal.
Re: moparts, i need some help [Re: Bigcube] #465368
09/12/09 12:58 AM
09/12/09 12:58 AM
Eagleville Tn.
rtstreet Offline OP
rtstreet  Offline OP
Eagleville Tn.
thanks, i thought about taking some stroke out of it and buying longer rods, same pistons. but hate to give up anything, car still has to weigh the same 3450.
Re: moparts, i need some help [Re: rtstreet] #465369
09/12/09 02:23 PM
09/12/09 02:23 PM
mi usa
O
old yeller Offline
old yeller  Offline
O
mi usa
Andy
if you need a motor to use for the NMCA event,i can bring the back up motor down to you,just let me know.
bird!
Re: moparts, i need some help [Re: old yeller] #465370
09/13/09 01:14 PM
09/13/09 01:14 PM
Eagleville Tn.
rtstreet Offline OP
rtstreet  Offline OP
Eagleville Tn.
Thinks bird might take ya up on that, call me later tonight
