SB MOPAR 360/408 EAGLE 4.00" CAST STEEL CRANK?????????? #463050
09/08/09 02:15 PM
09/08/09 02:15 PM
CA.
RAY1969CARS Offline OP
CA.
have you ran this crank????? can you give me input????? i see them on ebay for 265.00 can they take 500hp??? 7000rpm thanks guys mopar or no car!
Re: SB MOPAR 360/408 EAGLE 4.00" CAST STEEL CRANK?????????? [Re: RAY1969CARS] #463051
09/08/09 02:50 PM
09/08/09 02:50 PM
Look around the forged ones are around $500 range--they are easy to balance and that saves the diff in $$ usually making it a wash--some rod piston combos come up pretty easy with the cast but it is a crap shoot--could need Mallory metal or expensive flexplate etc--On the other hand I have made lots of them with cast and never had a problem but forged is better in the end IMO
Re: SB MOPAR 360/408 EAGLE 4.00" CAST STEEL CRANK?????????? [Re: RAY1969CARS] #463052
09/08/09 03:17 PM
09/08/09 03:17 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I wouldn't dream of takeing one to 7000. Even in a mild aplication they are a crap shoot. I have a friend with one he just wanted to have more power in his 5.9 magnum pickup and he installed a eagle stoker kit and had it checked and rebalanced locally and the front of the crank just snapped off on where the over lap is between the front crank pin and front main journal, there was a big bubble in there not to mention how much materiel is not there that is there on my SCAT crank and it was a disastor doomed from the begining and no magnaflux or anything would have detected it. His motor was very mild just had KB 356 pistons eagle rods no porting of anything and he even used a stock 5.2 magnum cam to get a little more tq with virtually no $$$ and it couldn't take that for a couple weeks and Eagle was of no help. Also if you look at there rods compared to a SCAT the differance is night and day and the metal is a much better quality so for the very minimal $$$ differance I would not use anything from eagle ever again, go with the SCAT and sleep well
Re: SB MOPAR 360/408 EAGLE 4.00" CAST STEEL CRANK?????????? [Re: RAY1969CARS] #463053
09/08/09 03:27 PM
09/08/09 03:27 PM
Not Eagle but i ran the Mopar cast in my 416,taking it to 7000 rpms several times with no issues,they were $400 when i built mine i think you can get them cheaper now..by the way the 416 made 520 h.p. and 500 lbs of tq...
Re: SB MOPAR 360/408 EAGLE 4.00" CAST STEEL CRANK?????????? #463054
09/08/09 03:36 PM
09/08/09 03:36 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
My mopar cast and forged 4 inch cranks both have the SCAT logo on them
Re: SB MOPAR 360/408 EAGLE 4.00" CAST STEEL CRANK?????????? [Re: HotRodDave] #463055
09/08/09 04:00 PM
09/08/09 04:00 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
yuph...scat made them for mopar ...
Tony
70 AARCuda Vitamin C
Re: SB MOPAR 360/408 EAGLE 4.00" CAST STEEL CRANK?????????? [Re: 70AARcuda] #463056
09/08/09 04:08 PM
09/08/09 04:08 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Even the big $$$$ billets. Mine doesn't have any logo on it.
Re: SB MOPAR 360/408 EAGLE 4.00" CAST STEEL CRANK?????? [Re: S/ST 3040] #463057
09/08/09 05:12 PM
09/08/09 05:12 PM
east coast
Otherlane Offline
Otherlane  Offline
east coast
I ran the mopar cast 4 in crank when they first came out 414 13 to 1 motor that saw 7000 rpm for 3 years without problems.the car ran 10.50@3300 pounds
Re: SB MOPAR 360/408 EAGLE 4.00" CAST STEEL CRANK?????????? [Re: RAY1969CARS] #463058
09/08/09 05:20 PM
09/08/09 05:20 PM
N.W. Indiana
DblOJoe Offline
DblOJoe  Offline
N.W. Indiana
Mancini had them for $239.00. You might want to check there first.
Re: SB MOPAR 360/408 EAGLE 4.00" CAST STEEL CRANK?????????? #463059
09/08/09 06:09 PM
09/08/09 06:09 PM
Q
Quicktree Offline
Quicktree  Offline
Q
how long did that motor last? just curious
Re: SB MOPAR 360/408 EAGLE 4.00" CAST STEEL CRANK?????????? [Re: Quicktree] #463060
09/08/09 06:53 PM
09/08/09 06:53 PM
Motor lasted 2 seasons until a ROD BOLT SNAPPED!!! ARP too...
Re: SB MOPAR 360/408 EAGLE 4.00" CAST STEEL CRANK?????????? [Re: RAY1969CARS] #463061
09/08/09 07:19 PM
09/08/09 07:19 PM
owt west
Thread Ender1 Offline
owt west
Are the Eagle Forged stroker cranks flawed also??
Re: SB MOPAR 360/408 EAGLE 4.00" CAST STEEL CRANK?????????? #463062
09/08/09 07:24 PM
09/08/09 07:24 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
What Rods?
Re: SB MOPAR 360/408 EAGLE 4.00" CAST STEEL CRANK?????????? [Re: Scamp408] #463063
09/08/09 07:25 PM
09/08/09 07:25 PM
S/ST 3040 Offline
S/ST 3040  Offline
What Rods?
Re: SB MOPAR 360/408 EAGLE 4.00" CAST STEEL CRANK?????????? [Re: Scamp408] #463064
09/08/09 07:31 PM
09/08/09 07:31 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
The favorite connecting rod of any serious small block build,eagle sir's. Can we say kaboom!!! 520hp in an Abody will get you 10.60's and 125 mph. May be 460 hp is the limit for the sirs.
Re: SB MOPAR 360/408 EAGLE 4.00" CAST STEEL CRANK?????????? [Re: RAY1969CARS] #463065
09/08/09 08:05 PM
09/08/09 08:05 PM
Az
Crizila Offline
Crizila  Offline
Az
I've got 2 seasons on mine in a 408 motor. Around 450HP at the rear wheels. Don't wind it to 7K though. I shift around 6 - 6200rpm.
Fastest 300
Re: SB MOPAR 360/408 EAGLE 4.00" CAST STEEL CRANK?????????? #463066
09/08/09 08:08 PM
09/08/09 08:08 PM
Q
Quicktree Offline
Quicktree  Offline
Q
yea right 2 seasons how many pases? the cheap SIRS you put in there is what broke. that and the 7000 rpms
Re: SB MOPAR 360/408 EAGLE 4.00" CAST STEEL CRANK?????????? [Re: RAY1969CARS] #463067
09/08/09 08:42 PM
09/08/09 08:42 PM
in front of the computer
8
80arrow Offline
80arrow  Offline
I ran a cast mopar crank in my 408 for 3 years, around 4-500 passes or so. It dynoed 553 horsepower and I don't remember the torque off hand. Only pulled it out to put in a 416. The engine builder said that with a cast crank not to use a transbrake with it.
Re: SB MOPAR 360/408 EAGLE 4.00" CAST STEEL CRANK?????????? [Re: 80arrow] #463068
09/08/09 08:58 PM
09/08/09 08:58 PM
St. Louis Mo.
10 o to go Offline
"Happy Don"
10 o to go  Offline
"Happy Don"
St. Louis Mo.
I ran my 410 cast crank with all transbrake launchs4000, 6800 shifts .Don't remember what rods ,arp bolts ,in the OHIO CRANK kit ,replaced crank too much alky oil then replaced with mopar C.C till death last year at MMW about 6 years of bracket racing for pts . Stepped up this year callies,probe pistons.
long run get forged crank
don
2009 418" build dan smith built new 9.96 131.82 6.23 108 1.30 60 foot best to date 9/15/09 8in 727 430 dana 2860 lb 3040 lb w driver
Re: SB MOPAR 360/408 EAGLE 4.00" CAST STEEL CRANK?????????? [Re: 10 o to go] #463069
09/08/09 10:24 PM
09/08/09 10:24 PM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
I bought a cast one for a 408ci interim motor for my F.A.S.T. Duster. It took me to 11.90 @ 114 which was very good considering how we had to run. I wrung it only to 6200 or so. The amount of meat in the arm between the 7/8 journal and the rear main bearing journal was scary to look at but didn't cause an issue.
One very nice positive is that it didn't need any mallory to internally balance. I ran Eagle H beams and SRP forgings.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
