what model/year 8 3/4 for 41' plymouth? #462914
09/08/09 08:54 AM
09/08/09 08:54 AM
San Jose,CA
migsBIG Offline OP
YouTube is my go-to news source
migsBIG  Offline OP
San Jose,CA
Since alot of folks have been giving good advice, thought I would ask a little more. Decided since the drivetain is gonna be upgraded, may aswell do the rearend. Now I usually have alot of access to many diffrent 8 3/4 rearend and those are pretty easy to service, so it's a no brainer. Figured I'd have to move the spring perches, so if I don't have to narrow one and slide it under would be a big plus. Anybody done which year/model of car 8 3/4 is the closest width for the car?
Re: what model/year 8 3/4 for 41' plymouth? [Re: migsBIG] #462915
09/08/09 10:23 AM
09/08/09 10:23 AM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline
Mopar Ron  Offline
I have used a "B" body rear end under36-38 cars and trucks, and they fit great so I would assume that they would fit a 41 just fine. 66-67 are just a little narrower than the 68-70 ones so one of those probably would be best Ron..
Re: what model/year 8 3/4 for 41' plymouth? [Re: migsBIG] #462916
09/08/09 03:44 PM
09/08/09 03:44 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Measure the dimensions of the existing rear end and compare to those in the archives:
http://www.moparts.org/Tech/Archive/axle/16.html
Re: what model/year 8 3/4 for 41' plymouth? [Re: John_Kunkel] #462917
09/08/09 09:13 PM
09/08/09 09:13 PM
orangeville,PA
P
plmczy Offline
plmczy  Offline
P
orangeville,PA
I had a 70 Barracuda gran coupe 8 3/4 housing mocked up in my 40 dodge. You only had to push the leafs out just a tad and the locating pins would pop right in to the spring perches. I wa told to use 55-57 chevy shock plates and it would bolt right up. The only thing is the chevy shock stud points out the front not the side like stock. later shawn
Re: what model/year 8 3/4 for 41' plymouth? [Re: John_Kunkel] #462918
09/08/09 09:47 PM
09/08/09 09:47 PM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
thanks again. Looks like 1966-70 b-body might be the way to go, though 190-e-body ones are bit hard to find. If I can get out and get the measurments on the plymouth rear, then I can get some real specs on it.
Re: what model/year 8 3/4 for 41' plymouth? [Re: migsBIG] #462919
09/09/09 04:56 PM
09/09/09 04:56 PM
Tracy CA
rabid scott Offline
"You're Where?"
rabid scott  Offline
"You're Where?"
Tracy CA
I have one from a 1969 Dodge Charger that will be going under my 1940 Dodge.
Re: what model/year 8 3/4 for 41' plymouth? [Re: rabid scott] #462920
09/09/09 10:02 PM
09/09/09 10:02 PM
Lithonia, Ga
3
36PLYM Offline
36PLYM  Offline
Lithonia, Ga
68 Coronet under the 36, perches fit right up, width is a great fit!
36 Plymouth Coupe
318 w/360 heads
518 trans
8 3/4 rear
Ga. Tech BCE'78
Re: what model/year 8 3/4 for 41' plymouth? [Re: rabid scott] #462921
09/10/09 05:08 AM
09/10/09 05:08 AM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
did you measure it up to use stock rims or are you going to use aftermarket rims and order as you need them?
I just scored a 1968 coronet rearend, delivered to my door for $200 bones.
