Re: dominator to scoop plate how to,ideas,tips. [Re: MegaDart] #460916
09/10/09 04:24 PM
09/10/09 04:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I just had to do mine again as big motor sits 3" taller
Thats how I did mine.... using the (what I call) ideal
entry... really helps smooth the air out
Re: dominator to scoop plate how to,ideas,tips. [Re: MegaDart] #460917
09/10/09 04:41 PM
09/10/09 04:41 PM
ELYRIA,OH
blownzoom440 Offline OP
ELYRIA,OH
i am looking for those to put on my scoop.i have not found them yet.
Re: dominator to scoop plate how to,ideas,tips. [Re: blownzoom440] #460918
09/10/09 04:47 PM
09/10/09 04:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Here is 1 version from Summit, I get them from Summit
or Jegs
http://www.summitracing.com/parts/QFT-200-1/
Re: dominator to scoop plate how to,ideas,tips. [Re: MR_P_BODY] #460919
09/10/09 04:54 PM
09/10/09 04:54 PM
ELYRIA,OH
ELYRIA,OH
also i was wondering about the side area to the carbs needed for correct air flow?any ideas?like with my narower scoop the stack would have no side taper but have front back taper.[ideal entry]
i need an airbell for a dominator 7.250 base.
update:i just saw this 1 from BG fuel systems
http://www.streetperformance.com/part/bg-fuel-systems/air-bellsair-bell-gasket/54515-110004.html
Re: dominator to scoop plate how to,ideas,tips. [Re: blownzoom440] #460920
09/10/09 08:03 PM
09/10/09 08:03 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
Applied Racing Technology has 2 different types of the air bell.
here is the new version of my scoop, I had a pan made at the local metal shop this time.
Re: dominator to scoop plate how to,ideas,tips. [Re: MegaDart] #460921
09/10/09 08:28 PM
09/10/09 08:28 PM
ELYRIA,OH
ELYRIA,OH
Thanks megadart!you have a nice big chamber to collect air.what are you using for a holddown?if i have to drill thru the top of the scoop for the stud i will.
Re: dominator to scoop plate how to,ideas,tips. [Re: blownzoom440] #460922
09/10/09 08:37 PM
09/10/09 08:37 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I am gunna use these 2 stage scoop
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: dominator to scoop plate how to,ideas,tips. [Re: hemi-itis] #460923
09/10/09 08:40 PM
09/10/09 08:40 PM
ELYRIA,OH
ELYRIA,OH
that is like having the blowers stacked right!
Re: dominator to scoop plate how to,ideas,tips. [Re: blownzoom440] #460924
09/10/09 08:49 PM
09/10/09 08:49 PM
hemi-itis Offline
hemi-itis  Offline
Sorta,just waiting to get a pair of dominators to put under the scoop,then turn the wick up
Re: dominator to scoop plate how to,ideas,tips. [Re: hemi-itis] #460925
09/10/09 09:09 PM
09/10/09 09:09 PM
ELYRIA,OH
ELYRIA,OH
i am using the 2 i have.
Re: dominator to scoop plate how to,ideas,tips. [Re: hemi-itis] #460926
09/10/09 09:18 PM
09/10/09 09:18 PM
ELYRIA,OH
ELYRIA,OH
1 thing i did not like was the adaptor plate is not open enough in the center for the dom'si will grind that out this winter.
Re: dominator to scoop plate how to,ideas,tips. [Re: blownzoom440] #460927
09/10/09 09:33 PM
09/10/09 09:33 PM
hemi-itis Offline
hemi-itis  Offline
Is that adapter plate supposed to be for a dommie???Or did you fab that up??
Re: dominator to scoop plate how to,ideas,tips. [Re: hemi-itis] #460928
09/10/09 09:41 PM
09/10/09 09:41 PM
ELYRIA,OH
ELYRIA,OH
it is for a domi.i got it from theblowershop.
Re: dominator to scoop plate how to,ideas,tips. [Re: blownzoom440] #460929
09/10/09 09:50 PM
09/10/09 09:50 PM
hemi-itis Offline
hemi-itis  Offline
Judging from the pic,,,,,,,,,it ain't big enough
Re: dominator to scoop plate how to,ideas,tips. [Re: blownzoom440] #460930
09/13/09 11:44 AM
09/13/09 11:44 AM
ELYRIA,OH
ELYRIA,OH
well it is on tho not ideal on the baseplate.
i need to start the car and set the idle with the new carbs.i had to order so jets for the carbs after removing the PV's that were not supose to be in there on both sides.
