Re: dominator to scoop plate how to,ideas,tips.
[Re: blownzoom440]
#460900
09/06/09 09:55 PM
09/06/09 09:55 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Show me a pic of a hilborn scoop just to make sure I know what it looks like... I'm pretty sure but want to make sure EDIT I see it now... the pic was slow loading..... what are you trying to accomplish... move the scoop upward
[Re: blownzoom440]
#460904
09/06/09 10:18 PM
09/06/09 10:18 PM
MR_P_BODY
i dont want any ill effects from the air going over the top of the carbs,flat or raised.the only opening in the scoop will be in the front opening.
Got your drift.... I would add 2 ideal entry's to the base of the scoop(thats what I call them) some call them velocity stacks.... might need to shorten the height of them some but they work great at getting the air to make the turn... thats what I have on my pan going into the carb. It will raise the scoop but that helps get the air in better
[Re: blownzoom440]
#460910
09/09/09 09:47 PM
09/09/09 09:47 PM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
here lies part of the problem with the carbs being as wide as the scoop i need to make the base wider than the scoop so it is all 1 piece.
