dominator to scoop plate how to,ideas,tips. #460896
09/06/09 06:30 PM
09/06/09 06:30 PM
ELYRIA,OH
blownzoom440 Offline OP
ELYRIA,OH
i cant get a baseplate for the dominator for my hillborn scoop.i dont want any ill effects like if i had a flat plate that the carbs stick thru and have it effect the air in a bad way.should i have a 1" taper to the carbs?effect?
thanks for any idea,info.
i have some .090 sheet i am cutting for the basic shape of the plate so can i cut a strip 1" and bent it in a circle and have it tig welded for the transfer to the carb?
please i dont want to CNC a billet 1.
Thanks!
Re: dominator to scoop plate how to,ideas,tips. [Re: blownzoom440] #460897
09/06/09 09:28 PM
09/06/09 09:28 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Re: dominator to scoop plate how to,ideas,tips. [Re: blownzoom440] #460898
09/06/09 09:44 PM
09/06/09 09:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Got any pics of your currant set up so we can come
up with some idea's
Re: dominator to scoop plate how to,ideas,tips. [Re: MR_P_BODY] #460899
09/06/09 09:49 PM
09/06/09 09:49 PM
ELYRIA,OH
ELYRIA,OH
up with some idea's
just 2 domi's under a hillborn scoop.it is a bit short in height4.5" but will have to do untel next yr.i just dont want the air to syphon the fuel blowing across the ventury and vent tubes for the bowls.
Re: dominator to scoop plate how to,ideas,tips. [Re: blownzoom440] #460900
09/06/09 09:55 PM
09/06/09 09:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Show me a pic of a hilborn scoop just to make sure
I know what it looks like... I'm pretty sure but want
to make sure
EDIT
I see it now... the pic was slow loading..... what are
you trying to accomplish... move the scoop upward
Re: dominator to scoop plate how to,ideas,tips. [Re: MR_P_BODY] #460901
09/06/09 09:57 PM
09/06/09 09:57 PM
ELYRIA,OH
ELYRIA,OH
Re: dominator to scoop plate how to,ideas,tips. [Re: blownzoom440] #460902
09/06/09 10:01 PM
09/06/09 10:01 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Re read my last post
Re: dominator to scoop plate how to,ideas,tips. [Re: MR_P_BODY] #460903
09/06/09 10:07 PM
09/06/09 10:07 PM
ELYRIA,OH
ELYRIA,OH
i dont want any ill effects from the air going over the top of the carbs,flat or raised.the only opening in the scoop will be in the front opening.
Re: dominator to scoop plate how to,ideas,tips. [Re: blownzoom440] #460904
09/06/09 10:18 PM
09/06/09 10:18 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Got your drift.... I would add 2 ideal entry's to
the base of the scoop(thats what I call them) some
call them velocity stacks.... might need to shorten
the height of them some but they work great at getting
the air to make the turn... thats what I have on my
pan going into the carb.
It will raise the scoop but that helps get the air
in better
Re: dominator to scoop plate how to,ideas,tips. [Re: MR_P_BODY] #460905
09/06/09 10:30 PM
09/06/09 10:30 PM
ELYRIA,OH
ELYRIA,OH
i certainly dont want to make the scoop any taller than i have to.it is even with the roof now. i was thinking of cutting/forming 2 1" x 22" long strips to make the stack and attach it to the baseplate.[no tapper,streight down]
Re: dominator to scoop plate how to,ideas,tips. [Re: blownzoom440] #460906
09/09/09 09:33 PM
09/09/09 09:33 PM
ELYRIA,OH
ELYRIA,OH
i have the baseplate opened.now i need to trim the sides to fit the scoop then i can raise it off the carb with a 1" strip and get it welded.i have another scoop also i am using as a backup.
Re: dominator to scoop plate how to,ideas,tips. [Re: blownzoom440] #460907
09/09/09 09:36 PM
09/09/09 09:36 PM
ELYRIA,OH
ELYRIA,OH
2
Re: dominator to scoop plate how to,ideas,tips. [Re: blownzoom440] #460908
09/09/09 09:38 PM
09/09/09 09:38 PM
ELYRIA,OH
ELYRIA,OH
3
Re: dominator to scoop plate how to,ideas,tips. [Re: blownzoom440] #460909
09/09/09 09:39 PM
09/09/09 09:39 PM
ELYRIA,OH
ELYRIA,OH
Re: dominator to scoop plate how to,ideas,tips. [Re: blownzoom440] #460910
09/09/09 09:47 PM
09/09/09 09:47 PM
ELYRIA,OH
ELYRIA,OH
here lies part of the problem with the carbs being as wide as the scoop i need to make the base wider than the scoop so it is all 1 piece.
Re: dominator to scoop plate how to,ideas,tips. [Re: blownzoom440] #460911
09/10/09 08:31 AM
09/10/09 08:31 AM
ELYRIA,OH
ELYRIA,OH
here is option 2.a shorter but wider scoop i will cut a baseplate for it today.
Re: dominator to scoop plate how to,ideas,tips. [Re: blownzoom440] #460912
09/10/09 08:36 AM
09/10/09 08:36 AM
ELYRIA,OH
ELYRIA,OH
2.2
Re: dominator to scoop plate how to,ideas,tips. [Re: blownzoom440] #460913
09/10/09 08:37 AM
09/10/09 08:37 AM
ELYRIA,OH
ELYRIA,OH
2.3
Re: dominator to scoop plate how to,ideas,tips. [Re: blownzoom440] #460914
09/10/09 03:19 PM
09/10/09 03:19 PM
ELYRIA,OH
ELYRIA,OH
ok guys time is a wasting!the carbs are on.
Re: dominator to scoop plate how to,ideas,tips. [Re: blownzoom440] #460915
09/10/09 04:15 PM
09/10/09 04:15 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
I just had to do mine again as big motor sits 3" taller
