Whats holding me in the 109 MPH range
#456589
09/01/09 05:27 PM
09/01/09 05:27 PM
Posts: 515 Dayton, Ohio
65cuda
mopar addict
mopar addict
Dayton, Ohio
i have went from low 13s to 12.05 never faster than 109.something. it's a 416 E heads out of the box , 509/510 comp cam , 4.11 gear , 3k stall 904,MT drag radials, 950 hp carb. weeland stealh dual plane. 1.63 best 60' through mufflers. think it's the dual plane?
65 Cuda 360,3.23 SG-13.97 @99.4, 88 D100, 2000 Kota Qcab, 71 Duster 416 11.84 @110., 73 Imp ,(2)72 & (1)71 Dart Swingers GarysMocars Legendary Dealer
Re: Whats holding me in the 109 MPH range
[Re: moper]
#456591
09/01/09 05:35 PM
09/01/09 05:35 PM
65cuda
mopar addict
mopar addict
Dayton, Ohio
it's always in the 109. something range. i think my best was 109.8
[Re: 65cuda]
#456592
09/01/09 05:35 PM
09/01/09 05:35 PM
Triple Threat
Renton Washington
I think the Intake leaves something to be desired yes. Go for something with a bigger plenum like the single plane M1 or Victor if you have bigger bolder plans down the road.
[Re: S/ST 3040]
#456594
09/01/09 05:52 PM
09/01/09 05:52 PM
65cuda
mopar addict
mopar addict
Dayton, Ohio
what do you guys think i should be running with this combo???
[Re: 65cuda]
#456595
09/01/09 05:58 PM
09/01/09 05:58 PM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
12.05 @ 109.8 is about right for each other.
Unless your Duster weighs 4000 lbs, it looks like you have some mismatched components or poorly machined/assembled engine.
I'd expect low 11s from a 416 in an A-body.
[Re: 65cuda]
#456597
09/01/09 06:11 PM
09/01/09 06:11 PM
Posts: 11,732 Portage,michigan
B3422W5
Portage,michigan
The cam is wrong, the intake is wrong, and the convertor is wrong...for starters.
Your car should be knocking on the door of the 10's , i would think. To me, you have a mismatched collection of parts that make it hard to acieve what the overall package is capable of running.
[Re: S/ST 3040]
#456598
09/01/09 06:12 PM
09/01/09 06:12 PM
65cuda
mopar addict
mopar addict
Dayton, Ohio
it being a 9.9 c/r pump gas motor would you still expect low 11s. it has been going faster every time i go to the track. i keep changing things.
[Re: 65cuda]
#456600
09/01/09 06:28 PM
09/01/09 06:28 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
Unfortunately you'll need to change quite a bit to get the mph and e.t. up. If you change the cam, then you'll need to change the springs too. Cam, springs, mild port job, victor intake and unless it's a real street car, a nice 4500 converter would do wonders but it'll be crap for the street. If you pull the heads to port them, change the springs and cam all at once, then do the victor intake it would probably pickup 8mph min!
Brian Hafliger
[Re: S/ST 3040]
#456601
09/01/09 06:36 PM
09/01/09 06:36 PM
65cuda
mopar addict
mopar addict
Dayton, Ohio
i see what u mean. What can a 416 do? A lot more. i should re ask my question what would help my combo the most. it runs good and feels strong to me. thats all relitive to what you are use to of course. its a cruze in car. i didn't think i was going to be racing it when i built it. But the bug has bitten me. now i am takeing it to the track.
[Re: 65cuda]
#456602
09/01/09 06:42 PM
09/01/09 06:42 PM
65cuda
mopar addict
mopar addict
Dayton, Ohio
Thanks Brian i see what u mean. guess i wil have to decide if it's going to be a street car or not.I think i will just try to get my best out of this combo then build one of my Darts for the strip.
[Re: 65cuda]
#456603
09/01/09 06:45 PM
09/01/09 06:45 PM
Posts: 5,898 Florida
Locomotion
![](/ubbthreads/images/graemlins/Twocents.gif) I think the carb is the "biggest" problem. Try a 750 carb and start tuning on it. (I had jets 3 #'s leaner on the upper level side of the Weiand with a 1" 4-hole tapered spacer.) I ran a Holley Strip Dominator and a Weiand Stealth, tuning the the 750 Holley DP for each, but not on exactly the same engine. Then I swapped intakes at a weekend event and went faster with the Strip Dominator.....but by less than a tenth. You have more head flow, but I have a lot more duration, gear, converter, etc. I don't think a higher rpm, single plane will help you. I also have a full exhaust - TTI headers, 3" x-pipe and ending with 3" Dynomax Ultraflos at the rear axle.
[Re: 65cuda]
#456604
09/01/09 06:47 PM
09/01/09 06:47 PM
S/ST 3040
What I'm used to? ![](/ubbthreads/images/graemlins/laugh2.gif) I'm currently building the biggest engine I've ever ran.......346" What does your car weigh? How tall are the drag radials? How big are your headers and exhaust system? You must have an XE284H cam?
[Re: 65cuda]
#456605
09/01/09 06:51 PM
09/01/09 06:51 PM
Posts: 429 Sherman Texas
The Shocker
Sherman Texas
Not trying to bragg ,just thought it may help.We both have A body's and stroker smallblocks .Mine is in a 64 Dart and its a 408 .It has (unported )Econo W2 heads,a wimp Edelbrock rpm cam ,750 Demon ,victor intake ,an adapted glide trans with 3,000 stall ,and 4.10 gears ,with 8.5 slicks .I have no traction devices on it and i leave at about 2600 on the foot brake.When i got the car it had a best in hot weather of 11.93 at 113.I have gutted 150 lbs off ,made a sealed scoop ,made and welded in sub connectors ,and done sum minor tuning.It has a best now of 11.71 ,but the same mph of 113.My problem is the cam is too small for the gear and im leveling out 100 ft from the end of the 1/4.It has went from a 7.58 best in the 1/8 to a 7.39 in the 1/8 ,with my mods to it.I have gained ET in the first half of the 1/4 ,but gained nothing on the big end.I think its your cam ,and gears that are not letting your motor go where it wants.I plan to tear mine down this winter and upgrade to a bigger solid cam.BTW ,my best 60' is identical to yours ,1.63 ...
[Re: S/ST 3040]
#456606
09/01/09 06:54 PM
09/01/09 06:54 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
I don't see it like that at all...
The cam matches the intake, which matches the converter, which matches the compression ratio, which matches the original intent of the car... it's a street car.
No doubt a 416" E-headed combo could be faster, but I don't think it's all that far off with the parts you have. It's a very reliable, low RPM, street combo.
However as everyone has said, there are certainly oppertunities to make the car faster. More cam, looser converter, porting the heads, etc... will all do wonders for the ET/MPH, but the drivability will be sacrificed.
These 4" crank motors seem to love carb, so I don't think putting a 750 on it would help. Especially since it doesn't have any HP/MPH at the big end. A smaller carb may help the bottom end, but not the top end.
If you wanted to keep it streetable, I would start with an intake, and a low gear set for the 904 (if it doesn't have one already). The lack of plenum volume in that intake is definately not helping. The low gear set would be a bandaid for the lack of converter stall speed too.
Those two things should pick it up without hurting the drivability at all, and neither one is all that pricy to do...
My ...
