Bronze dist shaft? #456018
08/31/09 09:38 PM
08/31/09 09:38 PM
Lexington,VA
68gtxsurvivor Offline OP
Lexington,VA
Where are you all getting your big block bronze dist shafts? I ordered one from summit for my 71 440 and its to long, anyone know of one that will drop right in and work? The one I ordered was a mopar performance brand.
Re: Bronze dist shaft? [Re: 68gtxsurvivor] #456019
08/31/09 09:54 PM
08/31/09 09:54 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
There are like 3 different ones depending on what pump you have.
Re: Bronze dist shaft? [Re: Bigcube] #456020
08/31/09 10:05 PM
08/31/09 10:05 PM
Lexington,VA
Lexington,VA
I have a melling high volume
Re: Bronze dist shaft? [Re: 68gtxsurvivor] #456021
08/31/09 10:18 PM
08/31/09 10:18 PM
AndyF Offline
AndyF  Offline
Mopar Performance and Milodon are the two vendors for oil pump shafts. They both make the short one that you need for a stock pump.
Re: Bronze dist shaft? [Re: AndyF] #456022
08/31/09 10:34 PM
08/31/09 10:34 PM
Lexington,VA
Lexington,VA
Would the Milodon 21525 work?
Re: Bronze dist shaft? [Re: 68gtxsurvivor] #456023
08/31/09 10:58 PM
08/31/09 10:58 PM
Motor City
Shaker223 Offline
Shaker223  Offline
Motor City
Re: Bronze dist shaft? [Re: Shaker223] #456024
08/31/09 11:22 PM
08/31/09 11:22 PM
huron,ohio
b1headman Offline
b1headman  Offline
huron,ohio
p3690875 mopar shaft will work with that pump
Re: Bronze dist shaft? [Re: 68gtxsurvivor] #456025
09/01/09 12:11 AM
09/01/09 12:11 AM
ky
68roadrunner Offline
ky
yes that is the one for a stock oil pump
