IMMEDIATE SUSPENSION HELP NEEDED!!! #456007
08/31/09 09:30 PM
08/31/09 09:30 PM
Wisconsin
BLONDE BARRACUDA Offline OP
Wisconsin
A friend came over with scales to help set up the car and we were wondering if there is a "formula" telling us what percent weight we want on driver side rear vs. passenger side rear. Our front to back percentage is 42.9 rear.
Thanks in advance
Re: IMMEDIATE SUSPENSION HELP NEEDED!!! [Re: BLONDE BARRACUDA] #456008
08/31/09 09:38 PM
08/31/09 09:38 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Typically the right side ends up a little heavier than the left.
Start out even, with fuel and driver and adjust more pre-load
to right side after track testing.
Re: IMMEDIATE SUSPENSION HELP NEEDED!!! [Re: BLONDE BARRACUDA] #456009
08/31/09 10:21 PM
08/31/09 10:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thanks in advance
What type of rear suspension, with the driver in the
seat at race weight try to get about 20# extra on
the RR... does the car have a anti roll bar on it,
if so dis-connect it to make sure its not applying
load... then hook it back up when done (set it at
neutral)... the 20# is just a starting point it may
what more or less depending on how the car launches
Re: IMMEDIATE SUSPENSION HELP NEEDED!!! [Re: MR_P_BODY] #456010
08/31/09 10:43 PM
08/31/09 10:43 PM
Wisconsin
Wisconsin
Good place to start.. thanks
