Re: 1/2" SLICK CLEARANCE ENOUGH?
[Re: 70dusterjohn]
#455479
08/31/09 11:04 AM
08/31/09 11:04 AM
Posts: 13,405 Marion, South Carolina [><]
an8sec70cuda
Thats alittle tight for me.. I like to see 3/4 to 1 inch.. Are you talking about to the side of the tire, or infront and to the rear.. I think for a drag car, the side clearance of 1/2 would be okay, but not the front or rear.. What size is the tire.. You gota think of growth...
Side to side I think 1/2" is OK. Front and rear you need more. I had a set of 30x12.5 ET Streets that tried to remove my 1/4 panels at 135 mph with only 1/2" clearance at the front. CHIP
