I just removed the rear seat and lost 66 lbs. from my ragtop dart , I seem to still have a issue with weight transfer to the rear tires on the srteet. At the track it will be fine ! >> the front end just does not come up fast enough
![](/ubbthreads/images/graemlins/shruggy.gif)
I have 4.5" front end travel already ... I have the 6 cyl. bars and ce 3 ways .... Complete cal trac set up . new hoosiers QTP 10.5" x27x15 . Fiberglass hood, front bumper and scoop with light weight Bumper braces and aluminum hood braces. NO hood latch just pins or hood tension bars . Do you think I would benefit more from caltrac front shocks or installing 100 # of Ballast in the trunk rear area
![](/ubbthreads/images/graemlins/smilie_help.gif)
HP Close to 500 ponies 500ft.lbs. tq.
The ragtop weight is approx. 3200# with out me in it.
Thanks for your opinions !
![](/ubbthreads/images/graemlins/wave.gif)
