Wierd clutch problem with my 69 Coronet RT?? #454922
08/30/09 09:13 PM
08/30/09 09:13 PM
NW New Jersey
RSI700VIPER Offline OP
NW New Jersey
OK, So I bought this Coronet RT awhile back and didn't have much time to play with it until recently. The clutch worked fine but the pedal would not return all the way back up unless you used the top of your foot. I then adjusted to factory spec so that resistance is felt after the pedal travels 1 inch, and now the pedal returns nicely BUT HERE IS THE PROBLEM... Now when I push the clutch down it bottoms out before hitting the floor. Like the clutch is fully engaged and can't travel anymore on the input shaft. Car appears to be all original. Could I have the wrong ratio z-bar or clutch fork??
1970 Superbird 440 Six BBL, 4-Speed, Dana, FJ5
1969 Daytona Charger 440 4-Speed, Dana, EV2
1971 340 Challenger Conv. Flemington Speedway Pace Car, FC7
1970 340 Six Pack Callenger T/A 4-speed T8 Tan
1971 340 Challenger RT Formal Roof, EV2 w/ V2 Stripe & Orange Houndstooth
1969 Talladega Torino, 428CJ
1969 Gurney Special Cyclone Spoiler II, 351 Cleveland
"Id rather have a bottle in front of me than a frontal lobotomy" Ben Franklin 1755
Re: Wierd clutch problem with my 69 Coronet RT?? [Re: RSI700VIPER] #454923
08/30/09 09:28 PM
08/30/09 09:28 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
That sounds like it's working right to me. It isn't supposed to hit the floor.
Re: Wierd clutch problem with my 69 Coronet RT?? [Re: stumpy] #454924
08/30/09 10:29 PM
08/30/09 10:29 PM
Since when?
Re: Wierd clutch problem with my 69 Coronet RT?? #454925
08/31/09 07:05 AM
08/31/09 07:05 AM
NW New Jersey
NW New Jersey
Re: Wierd clutch problem with my 69 Coronet RT?? [Re: RSI700VIPER] #454926
08/31/09 07:09 AM
08/31/09 07:09 AM
TX , NJ , FL
W
WINGCARS_6970 Offline
W
TX , NJ , FL
I think I remember .But wasnt there 2 different length adjusting bolts.From the Z bar to clutch fork
1969 Daytona 440 L9B410772 1970 Coronet 500 383 Presently owned 1970 Superbird 440 U 166242 1970 Superbird 440 U 174597 1970 Superbird 440-6 V 179697 1970 Coronet RT 440 U 224126 1968 Road Runner 426 J 134509 1970 Daytona Replica 318 G 178701
Re: Wierd clutch problem with my 69 Coronet RT?? [Re: WINGCARS_6970] #454927
08/31/09 09:15 AM
08/31/09 09:15 AM
NW New Jersey
NW New Jersey
I don 't think the length of the adjusting bar would have any affect as the distance it would travel would be the same, longer or shorter. However, if the fork were longer or shorter, or if the z-bar "leg" where the rods connect too are longer or shorter, this would affect the pedal travel vs. clutch travel ratio. My pedal travel vs throwout bearing travel seems way off.
Re: Wierd clutch problem with my 69 Coronet RT?? [Re: RSI700VIPER] #454928
08/31/09 04:01 PM
08/31/09 04:01 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I'd guess that a mismatch of parts is the problem.
If the pedal hits a hard stop before it reaches the floor there is probably an overcenter condition somewhere. If the pedal was over-traveling, the pressure plate fingers would hit the clutch disc.
Have somebody sit in the car and operate the pedal through its entire range, you should be able to see what's stopping the pedal.
Re: Wierd clutch problem with my 69 Coronet RT?? [Re: RSI700VIPER] #454929
08/31/09 06:31 PM
08/31/09 06:31 PM
MD
RTSE4ME Online content
RTSE4ME  Online Content
MD
Maybe the finger height needs to be adjusted correctly?
What type of PP do you have?
Re: Wierd clutch problem with my 69 Coronet RT?? [Re: RTSE4ME] #454930
08/31/09 06:55 PM
08/31/09 06:55 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If the pedal was meant to hit the floor then there wouldn't be a standard shift car with any carpet left under the clutch pedal. It's supposed to stop before it reaches the floor but not by much. All the pedal needs to move is enough to release the clutch fully anyway.
Re: Wierd clutch problem with my 69 Coronet RT?? [Re: stumpy] #454931
08/31/09 07:36 PM
08/31/09 07:36 PM
NW New Jersey
NW New Jersey
What's a PP? It just doesn't feel right. I have a 72 charger rallye w/ 440 and the pedal retuns all the way, and goes to the floor. I don't have to push it all the way to the floor to engage the clutch, but I am able too just the same. My RT pedal stops traveling about 3/4s of the way down if I adjust it so it returns all the way back. Or I can adjust it so it hits the floor, or almost hits the floor, but won't return back to the top without help from my foot. Must be mismatch parts or something with the clutch fingers or throw-out bearing. Is the fork shaft and z-bar unique to 440s? Car has matching 4-speed. Maybe it has the wrong bell housing with the pivot point for the fork shaft closer to the T_O bearing
Re: Wierd clutch problem with my 69 Coronet RT?? [Re: RSI700VIPER] #454932
08/31/09 07:42 PM
08/31/09 07:42 PM
Hunt Valley, Maryland
1fastrunner Offline
1fastrunner  Offline
I had all kinds of issues, all of which were corrected by Jamie Passon.
Here's what he replaced:
wrong clutch
wrong flywheel
wrong fork pivot
misaligned bell
worn z bar ends
wrong input shaft
He also reconditioned the shift rods, one was bent too bad and also had to be replaced.
The only problem I'm having now is the shaking of the front when I start in first. Something has got to be loose, but I still can't figure it out.
Re: Wierd clutch problem with my 69 Coronet RT?? [Re: 1fastrunner] #454933
08/31/09 08:29 PM
08/31/09 08:29 PM
NW New Jersey
NW New Jersey
jim,
The shaking when you let the clutch out is either the flywheel needs resurfacing (trued-up) or the crank is bent. I've also seen where someone cut the nib off on the end of the input shaft because the crank was not cut for a pilot bushing which cased vibration. Hard to believe all those items where wrong on your car. Are you sure the guy wasn't fishing?
Re: Wierd clutch problem with my 69 Coronet RT?? [Re: RSI700VIPER] #454934
09/01/09 09:10 AM
09/01/09 09:10 AM
1fastrunner Offline
1fastrunner  Offline
The Hayes clutch I had never worked right from the get go, they even sent me a free replacement, same problems. I had the wrong flywheel, the disc was hitting the bolts. The fork pivot was a small block as well as a small block bell. We reused the bell, but the bolt holes were striped and had to be replaced. the z bar ends were out of round pretty bad which caused it to be sloppy. The front shaft was also from a small block.
My motor was recently rebuilt and I have a brand new resurfaced flywheel, so I don't think those are the problem.
I could write a book about all the strange things I have found wrong in this car.
Re: Wierd clutch problem with my 69 Coronet RT?? [Re: 1fastrunner] #454935
09/01/09 10:09 AM
09/01/09 10:09 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
The most common problem we find is the bushings in the z-bar are worn or missing.
Re: Wierd clutch problem with my 69 Coronet RT?? [Re: B G Racing] #454936
09/01/09 12:21 PM
09/01/09 12:21 PM
1fastrunner Offline
1fastrunner  Offline
Thanks Bob,
Mine are all brand new, unless they weren't installed properly.
Re: Wierd clutch problem with my 69 Coronet RT?? [Re: stumpy] #454937
09/01/09 04:00 PM
09/01/09 04:00 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If so, what stops the pedal?
And, yes, you will find marks in the carpet where the pedal arm touches it occasionally, savvy drivers don't push it down all the way.
Re: Wierd clutch problem with my 69 Coronet RT?? [Re: John_Kunkel] #454938
09/01/09 05:48 PM
09/01/09 05:48 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
Had the same problem with my road runner. Brand new clutch plate throw out bearing resurfaced wheel rebuilt z bar pedal would only come up half way. Also clutch wouldn't last. Could not find the reason or problem finally got pissed off and sold the car. The clutches were Hayes
Re: Wierd clutch problem with my 69 Coronet RT?? [Re: Dougsmopars] #454939
09/01/09 06:19 PM
09/01/09 06:19 PM
!!! MAN !!! Some of you give up easy.
Look guys, this is simple. Clutches are simple mechanical devices. I know it's work I'VE BEEN THERE. I've probably had the 4 speeds in/ out of all my various Mopars I've owned some 30 times or more, I wasn't counting. So I know it's work. So get going. Get greasy. Get UNDER there.
First thing to do is inspect the linkage from one end to the other. Inspect the pedal bushings, the pedal, the rods, and espessially the "Z bar." Get a buddy to run the clutch in/out while you crawl under and look for things bending or moving that shouldn't, or not moving that should.
IF all else fails find a friendly friend/ shop/ etc with a press and "jig up" the flywheel, disk, and pressure plate and measure finger travel and disc clearance at release.
Put it back in the car and recheck. Bore a hole in the bell/ shield if you have to, to get a feeler ga. up in between the disc/ pp to check release. Take a GOOD look at things like the fork.
THIS IS SIMPLE MECHANICS and levers. There's nothing complicated about it.
DO NOT easily negate problems you think it "isnt" Is it the correct pp? Does it REALLY fit the flywheel? Right disc? in backwards? Bend/ bending fork/ linkage? Broken mount/ engine moving? Frame bracket loose/ cracked/ bending? Z bar cracked?
There CAN be stuff wrong with pressure plates, junk caught inside between the plate and cover, etc.
Is it the right Z bar? are the levers and rods the correct lenth so that the levers are near 90* to the rods in the "main" part of the swing?
Re: Wierd clutch problem with my 69 Coronet RT?? #454940
09/01/09 07:03 PM
09/01/09 07:03 PM
Dougsmopars Offline
Dougsmopars  Offline
This isn"t my first rodeo. Swapped many a clutch in the 35 years i've owned Mopars. I banged my head against the wall for allmost 3 years on the problem. Had many people look at it. Spoke to Hayes, replaced everything twice. Still only half a pedal. Enough was enough.
Re: Wierd clutch problem with my 69 Coronet RT?? #454941
09/01/09 07:38 PM
09/01/09 07:38 PM
NW New Jersey
NW New Jersey
sixpack- lots of good advise. I'll "get greasy" and see if something looks out of place. I suspect though it;'s a mismatch part. Does anyone have the part number for the clutch fork and z-bar as these are the lever multipliers?
