Again! best Oil #454740
08/30/09 05:08 PM
08/30/09 05:08 PM
Annapolis, Missouri USA
CIB Offline OP
CIB  Offline OP
I know this has been beat to death, but I been running 15-40 Rotella with ZPPD for a couple of years since freshening engine. I noticed some posts claiming long term use of such could do more damage than good. What would be the best oil to use with ZDDP for a 440 street engine?
Re: Again! best Oil [Re: CIB] #454741
08/30/09 05:16 PM
08/30/09 05:16 PM
S.E. Conn
Hoof Hearted Offline
S.E. Conn
2005 300C Hemi
2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
Re: Again! best Oil [Re: Hoof Hearted] #454742
08/30/09 05:33 PM
08/30/09 05:33 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
I agree it's beat to death. I break my engines in with a GOOD Quality 30 weight with Comp's additive then run Valvoline VR1 10-30 after that. never had a problem
Re: Again! best Oil [Re: CIB] #454743
08/30/09 10:35 PM
08/30/09 10:35 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
You can use the Heavy Duty Engine Oils (HDEOs) in older gasoline engines just fine. Many people here are doing so and have good luck.
This directly from the Shell Rotella main page: "Many gasoline engines, especially the hard-working engines of pickup trucks, sport-utility vehicles (SUVs), minivans and motorcycles"
Recent lab reports have Zinc content of the new formula CJ4 Rotella in the 1200ppm range, which is an accepted level for flat-tappet cam use.
Some fear this Zinc level may be reduced at any time without warning.
If you don't want to continue to use HDEOs, there are many options out there for high zinc non-HDEO motor oil.
Re: Again! best Oil [Re: CompSyn] #454744
08/30/09 10:39 PM
08/30/09 10:39 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Also depends a lot on the lift/duration of your cam and the tension on your valve springs. Gonna be a big difference in how concerned you need to be between a stock cam/springs and an aftermarket setup with .6 of valve lift and 600# spring pressures.
Re: Again! best Oil [Re: CIB] #454745
08/30/09 11:16 PM
08/30/09 11:16 PM
I have the same concern. I just primed my engine with a drill and it made 80 PSI. Am just as concerned about the intermediate gear as I am about the cam and lifters. Do you think I'd need a bronze gear? Bill
Re: Again! best Oil #454746
08/31/09 07:20 AM
08/31/09 07:20 AM
CIB Offline OP
CIB  Offline OP
I do have a higher lift cam and valve springs. So what oils do you reccomend?
Re: Again! best Oil [Re: CIB] #454747
08/31/09 07:35 AM
08/31/09 07:35 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
I run Rotella for my flat tappet cams. Anything on sale for newer daily drivers. You definately have to pick an oil for your application as is why there are a few custom oil companies. Everyone I've talked to lately is fawning over Brad Penn oils.
Re: Again! best Oil [Re: redraptor] #454748
08/31/09 08:05 AM
08/31/09 08:05 AM
Az
Crizila Offline
Crizila  Offline
Az
I run a big Hyd ( over .600 lift ) flat tappet cam and use Royal Purple racing oil with a zinc additive. No problems so far.
Fastest 300
Re: Again! best Oil #454749
08/31/09 04:41 PM
08/31/09 04:41 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
what motor and cam. oil pressure will not hurt anything and goes down quick when hot. bronze gears are for performance roller cams not sure about stock hydraulic rollers though?!!
Re: Again! best Oil [Re: Dodgem] #454750
08/31/09 04:47 PM
08/31/09 04:47 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I think the reason you run bronze on a roller as rollers are billit steel not cast and the need for dis similar metal contact?? something like that??
Re: Again! best Oil [Re: Dodgem] #454751
09/02/09 02:02 PM
09/02/09 02:02 PM
CIB Offline OP
CIB  Offline OP
How about 10W40 valvoline or 10W40 castrol gtx? Are these good oils for a street 440? Would I need ZDDP?
Re: Again! best Oil [Re: CIB] #454752
09/02/09 09:30 PM
09/02/09 09:30 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
most believe you need additive with any SM rated oil.
Re: Again! best Oil [Re: redraptor] #454753
09/03/09 09:40 AM
09/03/09 09:40 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
One of the reason a lot are switching to Brad Penn,check the Zinc content.
Re: Again! best Oil [Re: CIB] #454754
09/03/09 10:16 AM
09/03/09 10:16 AM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
I run VR1 in my Hemi w/ 590 solid & no problems. Easier to find than the Brad Penn I used to use & a lot cheaper. Check out www.bobistheoilguy.com for more info about your question.
Re: Again! best Oil [Re: Triggerfish] #454755
09/03/09 11:17 AM
09/03/09 11:17 AM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
I run valvoline Vr1 20w-50 in my car. I ran two samples so far and the zinc is 1172ppm.
The only Carbs I care about are under the hood!
Re: Again! best Oil [Re: Azzkikrcuda] #454756
09/05/09 05:23 PM
09/05/09 05:23 PM
Baton Rouge, La.
StandOnIt Offline
StandOnIt  Offline
Baton Rouge, La.
I run Royal Purple in just about everything I own. I have never had an oil related failure with it.
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
Re: Again! best Oil [Re: StandOnIt] #454757
09/05/09 09:04 PM
09/05/09 09:04 PM
Willoughby Hills, Ohio
gd9704 Offline
super gas
gd9704  Offline
super gas
I've been running Rotella 15w-40 for a few years. I don't like that my oil pressure is a bit high with the 40 weight oil. This fall I'll change to a non-specialty 10w-30 with a dose of ZDDPlus.
Re: Zinc Content [Re: gd9704] #454758
09/06/09 01:13 PM
09/06/09 01:13 PM
Iron Station, NC
furygt Offline
furygt  Offline
Iron Station, NC
Rotella is now SM rated. I know that some feel that you need SL rated oil for older engines with flat tappet cams. Tractor Supply Company's house brand oil is also a 15w 40 oil and it still has an SL rating and is available in container sizes from a quart up to a 5 gallon pail.
Bill
