Mopar Rallye Wheels #454408
08/30/09 12:21 PM
08/30/09 12:21 PM
Northeastern, Pa
P
Purphaz Offline OP
Purphaz  Offline OP
P
Northeastern, Pa
Hello. I'm going to purchase a set of 15x7 and wider 15x8 rallye wheels and I wanted to know what was the correct look for these wheels on a 1971 Plymouth Road Runner.
Do you use the brushed ring? Is the center cap the dark gray or light gray color?
Thank you,
Adam
Re: Mopar Rallye Wheels [Re: Purphaz] #454409
08/30/09 12:27 PM
08/30/09 12:27 PM
Kent, WA
triple_green Offline
Kent, WA
my research said dark argent centers, brushed trin rings. I don't think you can get a trim ring that will fit wider than the 7" wheel...so I understand that is what you have to use on the 8" wheel too.
Others please correct me if I am wrong.
3X
68 Charger, 383 HP console auto, spring green, stock restoration
Re: Mopar Rallye Wheels [Re: Purphaz] #454410
08/30/09 12:28 PM
08/30/09 12:28 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
Darker center for 71. I use brushed on my car.
