Re: Ate the top of a lifter
[Re: Michael]
#453998
08/29/09 11:16 PM
08/29/09 11:16 PM
Posts: 43,359 Bend,OR USA
Cab_Burge
The lifter is faulty, not the first set of Mopar size .904 solid lifters to do that ![](/ubbthreads/images/graemlins/scope.gif) You should take the motor apart and see what other colateral damges there are, cylinder walls, piston skirts, oil pump, camshaft and so on ![](/ubbthreads/images/graemlins/scope.gif)
[Re: Cab_Burge]
#453999
08/30/09 12:55 AM
08/30/09 12:55 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
i had the lifter cup start eating itself on the inside of the lifter body. like you, nothing wrong with the lifter body at all, just the cup that sits in it
one of the reason i moved onto lifters with wheels
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: 440Jim]
#454001
08/30/09 09:11 AM
08/30/09 09:11 AM
Posts: 6,185 Bridgeport, WV
Michael
Bridgeport, WV
Sometimes you can just replace the lifter pushrod seat and keep the lifter on the lobe it came from.
I would like to do that to all of them. Who does that?
