Distilled water in radiator? #453262
08/29/09 12:01 PM
08/29/09 12:01 PM
Indiana
rapid67rt Offline OP
Indiana
Thought I read somewhere that you should use distilled water when filling your radiator?
Re: Distilled water in radiator? [Re: rapid67rt] #453263
08/29/09 12:04 PM
08/29/09 12:04 PM
Kirkland, Washington
Pacnorthcuda Offline
Its a good practice, yes.
Re: Distilled water in radiator? [Re: Pacnorthcuda] #453264
08/29/09 12:42 PM
08/29/09 12:42 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Re: Distilled water in radiator? [Re: Pacnorthcuda] #453265
08/29/09 01:09 PM
08/29/09 01:09 PM
CHRGR69 Offline
CHRGR69  Offline
Actually, if the tap water is high in minerals, especially well water, it increases the chance of overheating.
Re: Distilled water in radiator? [Re: CHRGR69] #453266
08/29/09 01:16 PM
08/29/09 01:16 PM
Tell ya a true story about distilled water.
When I was at Miramar (San Diego) I ran around with a guy who was becoming (and now is) an engineer. He was one of these guys who was difficult to convince the engineers didn't do everything right.
Had a 70 Chev 3/4T 4x4, bought new. We'd finally got him to put a 350hp cam in the thing after the factory cam went flat, but he refused to use an all steel cam drive. So around 74 just before I got out of the Navy, we had it torn down--to replace the phenolic cam sprocket.
He'd used 50/50 antifreeze and distilled water (San Diego water is horrid with minerals) and the INSIDE OF THE WATER PASSAGES LOOKED ABSOLUTELY LIKE NEW
Re: Distilled water in radiator? [Re: rapid67rt] #453267
08/29/09 01:40 PM
08/29/09 01:40 PM
Bridgeport, WV
Michael Offline
Michael  Offline
Bridgeport, WV
Re: Distilled water in radiator? #453268
08/29/09 02:35 PM
08/29/09 02:35 PM
I'm convinced
Re: Distilled water in radiator? [Re: rapid67rt] #453269
08/30/09 06:26 PM
08/30/09 06:26 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
or you could buy the 50/50 mix
Re: Distilled water in radiator? [Re: Dakota_Don] #453270
08/30/09 06:36 PM
08/30/09 06:36 PM
We sure like to pay big $ for water nowadays don't we?
At Schucks I see the 50/50 going for about 75% of the cost of 100% gallon for gallon. Then I see they are selling "Mineral Water" (they mean
demineralized water, but don't seem to notice the difference when making their sign ) for $2.49 a gallon. (gulp). The local grocery store has distilled for 79 cents.
Re: Distilled water in radiator? [Re: Pacnorthcuda] #453271
08/30/09 08:35 PM
08/30/09 08:35 PM
So that is what mineral water is (I never paid any attention to it) and if distilled is more pure & it's cheaper and the car (& me) will live longer from using distilled I dont see any downsides to it unless I'm missing something.
Re: Distilled water in radiator? [Re: RapidRobert] #453272
08/30/09 08:39 PM
08/30/09 08:39 PM
No, "Mineral Water" is HIGH in minerals and is the last thing you want to put in a radiator or battery. Distilled water is De-mineralized, the distallation process leaves the minerals in the orginal vessel. Schucks was selling "de-mineralized water" (good) but their little in-store sign called it "Mineral Water". My post wasn't clear.
Re: Distilled water in radiator? [Re: Pacnorthcuda] #453273
08/30/09 08:48 PM
08/30/09 08:48 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
what does a gal of distilled water cost, not to mention you will have to go shopping for it.. if your in a hurry then te 50/50 mix is a good way to go..
Re: Distilled water in radiator? [Re: Pacnorthcuda] #453274
08/30/09 08:54 PM
08/30/09 08:54 PM
Now I got it.
Re: Distilled water in radiator? [Re: RapidRobert] #453275
08/30/09 09:47 PM
08/30/09 09:47 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Distilled is less than a buck a gallon at Wally World or Kroger or ???? Pretty common.
I want my fair share
Re: Distilled water in radiator? [Re: SomeCarGuy] #453276
08/30/09 10:33 PM
08/30/09 10:33 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
My local parts store sells de-ionized water in their anti-freeze section for about a dollar a gallon. I buy two gallons of coolant and two gallons of their water and am good to go. Don't know if it helps but it sure can't hurt.
FWIW two years ago I put a new alum rad in my sig car and filled it with the above. It still looks 100% clean/new inside.
Re: Distilled water in radiator? [Re: DaytonaTurbo] #453277
08/30/09 11:03 PM
08/30/09 11:03 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
they say deionized water is bad. distilled water is best. ive never had any problem running straight tap water
