rear parts #451123
08/26/09 07:34 PM
08/26/09 07:34 PM
Pa. bucks county
cuhemida Offline OP
cuhemida  Offline OP
Pa. bucks county
hey guys im building a 48 dodge coupe all mopar but the rear which is a 1986 ford 8.8 having a small problem finding e-brake parts they made 2 e-brake one the rotor has a brake drum built in it the other the e-brake works thru the calapire they have linkage on the cal. that hooks to the e-brake and when pulled it clamps the cal. to the rotor i hope o got this out so someone understands what im looking for i need the set uo that uses the cal. for the e- brake
a little help would be great
Tom
Re: rear parts [Re: cuhemida] #451124
08/26/09 11:30 PM
08/26/09 11:30 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
What parts are you looking for? The cables, the calipers, small parts?
If the dealer can't help, try aftermarket...
Rock auto lists
Buyer's Guide: RAYBESTOS FRC5252 Caliper
FORD MUSTANG SVO (1984 - 1986)
LINCOLN CONTINENTAL (1982 - 1987)
LINCOLN CONTINENTAL GIVENCHY 1987
LINCOLN MARK VII (1984 - 1987)
LINCOLN MARK VII BILL BLASS (1987 - 1990)
LINCOLN MARK VII LSC (1987 - 1990)
as one possible rear caliper
Re: rear parts [Re: RodStRace] #451125
08/27/09 07:21 PM
08/27/09 07:21 PM
Pa. bucks county
cuhemida Offline OP
cuhemida  Offline OP
Pa. bucks county
i can get the calapires about any where it the linkage on the cal. i can find its the linkage the make it work as the e- brake that hooks to the e-brake cable
