is my carb big enough?
#449674
08/25/09 04:02 PM
08/25/09 04:02 PM
Posts: 79 montreal, quebec, canada
jimmy71demon
i got a holley 650 double pump carb that i had on my 340 before. now im soon gonna be ready to put my 416 stroker in. is my carb gonna be big enough to supply it? thanks in advance
Im goin fast Mom!
Re: is my carb big enough?
[Re: jimmy71demon]
#449675
08/25/09 04:11 PM
08/25/09 04:11 PM
Posts: 1,373 Rancho Cucamonga, CA
D_C
According to Holley.Com, YES. 650 CFM should be fine for your 416 CID (depending on maximum RPM.) A 700 or 750 CFM might work well too. View the Holley Chart (link below) and remember, you never get 100% efficiency from a naturally aspirated engine (more like 85% to as-much-as 95%, but that is closer to a Pro Stock engine.) On the lower end (6,000 RPM, 85% V-Efficiency) a 637 CFM carb is enough. At maximum 8,000 RPM, 85% VE, an 800 CFM carb would be a better choice. The 650 CFM is good to 6,000+ RPM though you should make some upgrades to that carb (correct Power-Valve, jetting, accelerator-pump, squirters, etc. Generally speaking, the smaller the throttle bores,the better the throttle response. Also, a mistake many people make is over-carburetion. Here is the Advice directly from the Manufacturer (Holley) on selecting the Right Size Carburetor: Selecting the Right Size Carburetor, Holley.
[Re: jimmy71demon]
#449676
08/25/09 04:43 PM
08/25/09 04:43 PM
Posts: 4,002 Joplin, Mo
rt66jim
Joplin, Mo
Well you didn't say what heads and cam you were running. Or whether it street or strip. My W2 headed 416 with a 272@050 612 lift cam. Loves my 950HP. IMO a 650 will not allow that motor to run to it's full potential. Jim
[Re: Dodgem]
#449679
08/25/09 06:00 PM
08/25/09 06:00 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Make that "two" satisfied 950 Holley users, we just dyno'd my friends 422 340 stroker, ported W2 heads, milder cam than above, still liked the 950 over a 750 DP, and an 800 AVS ("liked" = about 30 more HP than either of the other carbs). We never ran a Thermoquad but I'd say a nicely tuned TQ would hold it's own against any of them in terms of overall performance.
[Re: Dougsmopars]
#449684
08/25/09 06:28 PM
08/25/09 06:28 PM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Shame they don't still make them. Back in the day them were the best carbs out there.
It's no big deal that they aren't being made anymore, there are still plenty of good core originals out there (usually CHEAP) and most parts are still available. A thorough rebuild and you can have one that's as good or better than anything ever sold new.
[Re: BIG-MIKE-500 ci]
#449688
08/25/09 07:51 PM
08/25/09 07:51 PM
Posts: 498 El Dorado Ca
65signet
El Dorado Ca
I have 340 mild cam headers eddys, and i tried all holleys, but a 650,700,750,830 comp series, and a ported 800, the throttle response was good with smaller carbs, but no good at the track, it ran the quickest with the ported 800 but it was a little to much the 750 works the best for all around, and i think it will work better after i do a port job to it.
1965 Plymouth Barracuda 273 M/SA 1970 Plymouth Duster 360/904 10.60s with J heads
