Page 24 of 29 1 2 22 23 24 25 26 28 29
Re: ONE DOWN , ONE TO GO ! [Re: ScottSmith_Harms] #449570
03/25/12 02:36 PM
03/25/12 02:36 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
This engine is for sale.
Work of art! How much? Are you building a different even more hostile one? (gulp! )
As I understand it from my boss George, Ron sold the Valiant to his friend w/the 408 in it and that the motor was hurt but maybe he fixed it...........
Re: ONE DOWN , ONE TO GO ! [Re: Thumperdart] #449571
03/25/12 07:01 PM
03/25/12 07:01 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
This is what I got from Ron. I have nothing to do with this engine or anything else of Rons .
Yes the 501 is for sale. It was in the Valiant for about 8 months and probably has about 20 passes on it. Plus about 300 street miles. But, it was hurt when I took it out. It had dropped a Valve/broke a retainer. So, I pulled the one head and the piston was ok and I had the guide replaced and replaced the VVs in that cylinder etc and put the head back on.
The thing is, the machine shop showed me where the valve seats were crumbling. Indy had put some cheap valve seats in these heads. I sent pics to RyanJ and he said to just run it. It also had some cylinder scuffing from the pistons rocking at TDC. (short piston with 4.5” stroke) He also said that would not be an issue. He said he rebuilt motors that had scuffing like that and they did not pick up much if at all and that I was probably not losing any ET to speak of. The day the car dropped the Valve it turned 1.34 60 foot time and would have probably run high 9 seconds but there were Santa Ana Winds so I was not making full passes. At Fontana.
So, I reinstalled the head and I was replacing the retainers on the OTHER head. RyanJ/CompCams sent me new ones. I put air on the cylinders to hold the valves closed. Well, the air leaked so bad out the intake ports it sounded like a Jet Plane. So I knew right then that the valve seats were not going to cut it. I pulled the heads off the motor and spent $5000 fixing them the right way.
The heads now have all new Xceldyne copper beryllium valve seats all blended in with a race valve job. All new Xceldyne bronze guides. New Titanium intake valves, new special alloy hollow stem exhaust valves, new Titanium retainers, machined locks and seals. The Valve springs are a Manley NexTec double spring. The heads were surfaced and installed exactly how I did the first time with Cometic MLS gaskets. The motor is all back together now and ready to go. I also put new pushrods in it because they had contacted the steel shim in the VV cover gasket and believe it or not that galled some of them so bad I was afraid of failure. It also allowed me to refine the length to get the adjuster screws in a more ideal place. I also put air on all the cylinders since reinstalling the heads and there is no noticeable air leaking any more. So I do believe the scuffing will not be an issue. I can give a lot more details if someone is serious and wants to call me. I have had the pan off to repair it after I smashed it doing wheelies (twice), so I inspected a few bearings and they were ok etc. I replaced the oil pump because the pressure gauge was acting a little weird, but that seems to have fixed that etc. I 100% planned on keeping the motor and running it in another car including a driver, but a lot of the cars I am looking at buying already have good motors. So I decided to try and sell it and see what happens. I think it would cost about $28,000 to build this motor now with the upgraded heads/vvs/seats etc.
I also have custom Headers I built for this motor that I have put a LOT of work in them to get the ports/flanges to match properly and they are ceramic coated. I have over $1200 in materials/coating! They were smashed but have been fixed/recoated.
The motor will come with the Vacuum pump and a one wire alternator with the mandrel drive as pictured. Everything else in the short block is per that thread on Moparts.
Re: ONE DOWN , ONE TO GO ! [Re: justinp61] #449572
04/23/12 09:30 AM
04/23/12 09:30 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Re: ONE DOWN , ONE TO GO ! [Re: MattW] #449573
04/23/12 11:47 AM
04/23/12 11:47 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Ron was at the MATS in his Challenger. I did not get a chance to talk to him however. Also the Valiant was out there. I did see a female driving it though. He is a great guy to bad we dont see him around here anymore but I understand his reasons.
Re: ONE DOWN , ONE TO GO ! [Re: Al_Alguire] #449574
04/23/12 11:57 AM
04/23/12 11:57 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Yes, Ron is a good guy. Walked around the swap and spoke with him for about 45 minutes on Saturday at Spring Fling.
He's looking for a survivor type 70-71 Duster/Demon, non ac car. If anybody knows where one is, let him know.
Re: ONE DOWN , ONE TO GO ! [Re: RobX4406] #449575
04/23/12 01:48 PM
04/23/12 01:48 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
Wonder what he wants for it?? Is it all back together or in pieces??
Re: ONE DOWN , ONE TO GO ! [Re: MIKES_DUSTER] #449576
04/23/12 03:40 PM
04/23/12 03:40 PM
Glendale Az
Darryls-Demon Offline
Glendale Az
I talked to Ron last week end at the Sring Fling car show and he does still have it.
Re: ONE DOWN , ONE TO GO ! [Re: MIKES_DUSTER] #449577
04/23/12 03:44 PM
04/23/12 03:44 PM
Glendale Az
Glendale Az
I talked to Ron last weekend at the Spring Fling car show and he does still have it.
Re: ONE DOWN , ONE TO GO ! [Re: Randy..] #449578
04/27/12 01:49 AM
04/27/12 01:49 AM
Mcallen, TX
SB449VALIANT Offline
Mcallen, TX
come on Ron, we need you on here.
Re: ONE DOWN , ONE TO GO ! [Re: MIKES_DUSTER] #449579
06/10/12 12:57 PM
06/10/12 12:57 PM
USA
Ron Silva Offline OP
USA
S O L D
SRT DEMON ONE SEAT
Re: ONE DOWN , ONE TO GO ! [Re: Ron Silva] #449580
06/10/12 03:32 PM
06/10/12 03:32 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
I have seen that motor run in person, one bad azz small block.
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
Re: ONE DOWN , ONE TO GO ! [Re: 65signet] #449581
06/10/12 04:18 PM
06/10/12 04:18 PM
Mcallen, TX
Mcallen, TX
Agree... i wish i had the money,owner is Indeed a man with an oustanding dedication/skills....
Re: ONE DOWN , ONE TO GO ! [Re: SB449VALIANT] #449582
03/17/13 11:57 AM
03/17/13 11:57 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
OK what is Ron up to now?
Does anyone know of any web site he now ventures to?
I miss his posts. Matt
Re: ONE DOWN , ONE TO GO ! [Re: MattW] #449583
03/17/13 12:36 PM
03/17/13 12:36 PM
Q
Quicktree Offline
Quicktree  Offline
Q
same here, you need thick skin around here. a shame he holds grudges and can't let it go. everyone needs time to cool down sometimes but life is to short to hold grudges no matter what happened.
Re: ONE DOWN , ONE TO GO ! [Re: Quicktree] #449584
03/17/13 01:21 PM
03/17/13 01:21 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
You guys that wish he was back seem to be the same group that ran him off lol
Re: ONE DOWN , ONE TO GO ! [Re: FastmOp] #449585
03/17/13 01:24 PM
03/17/13 01:24 PM
RobX4406 Offline
RobX4406  Offline
BAZINGA!!!
Re: ONE DOWN , ONE TO GO ! [Re: FastmOp] #449586
03/17/13 01:27 PM
03/17/13 01:27 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`ve talked to Ron and even raced w/him at the track and agree about the thick skin but sometimes things are said that can really piss ya off and must admit that I considered a plane ticket to meet the "mouths" in person to square things up. That was then and time CAN heal for some and others like Ron, well they just move on knowing their skills and knowledge are greater than the idiots slingin mudd.................
Re: ONE DOWN , ONE TO GO ! [Re: Thumperdart] #449587
03/17/13 03:19 PM
03/17/13 03:19 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
So is he hanging out somewhere else?
Re: ONE DOWN , ONE TO GO ! [Re: FastmOp] #449588
03/17/13 03:24 PM
03/17/13 03:24 PM
Q
Quicktree Offline
Quicktree  Offline
Q
explain how you can run someone off?
Re: ONE DOWN , ONE TO GO ! [Re: Quicktree] #449589
03/17/13 04:46 PM
03/17/13 04:46 PM
Riverside, Ca
G_bob Offline
G_bob  Offline
Riverside, Ca
Start talking about pinion angles....
