727 tranny toast?-UPDATE-NOT TOAST! :)
#448872
08/25/09 09:35 AM
08/25/09 09:35 AM
Posts: 203 Washington, PA.
69charger383
Washington, PA.
A friend just bought a 68 charger 383/727 combo. The car runs & drives real good. He drove the car home from the seller's house which was 450 miles away without any problems at all. When we started checking the car over, we discovered there is no kickdown linkage for the tranny. Someone pulled the kickdown lever on the tranny all the way forward & put a spring on it to keep it there. My friend said he did not get on it at all on the way home & babied it. Is this tranny toast, or if he puts a kickdown set-up on it (Bouchillon kit)& sets it properly will it be OK? He said when he was checking out the car, he was so excited, he just didn't notice that the linkage was not there.
Re: 727 tranny toast?
[Re: Dodgem]
#448875
08/25/09 10:12 AM
08/25/09 10:12 AM
Posts: 15,487 Florida
scratchnfotraction
hook the Bouchillon kit and try it 50/50 chance IMO may get lucky,as it seems to be working still,and he took it easy on the trip... good luck
[Re: scratchnfotraction]
#448876
08/25/09 11:19 AM
08/25/09 11:19 AM
The "kickdown linkage" really only increases line pressure.
If it was babied then there is a good chance it's OK.
Really, though, if you don't know it's history the seals and clutch material is going to be pretty well shot unless it was rebuilt at some point.
I just did a '73 727 with 60k orignal miles. While it looked VERY nice inside there was evidence that the bands and the clutches were starting to flake after 35 + years of use and the seals were hard and brittle as well.
[Re: stumpy]
#448879
08/25/09 11:30 AM
08/25/09 11:30 AM
Posts: 3,358 Berwyn, IL
challenger70
Berwyn, IL
Max pressure is all the way back.
Then why would you put a spring to keep it there? Some of the stuff you find on these cars will make you go nuts
[Re: challenger70]
#448880
08/25/09 11:59 AM
08/25/09 11:59 AM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
Because the person that did it is a MORON .
[Re: etek]
#448881
08/25/09 12:00 PM
08/25/09 12:00 PM
JohnRR
U.S.S.A.
As you know, it just "kicks down" the gears when you boot it (old term!)...let us know what happens!!!
That statement couldn't be more WRONG ...
[Re: etek]
#448883
08/25/09 01:11 PM
08/25/09 01:11 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
. As you know, it just "kicks down" the gears when you boot it (old term!)...let us know what happens!!!
WRONG The kick down linkage is a misname for the throttle pressure control linkage which more than anything else controls pressures in the transmission throughout the travel of the throttle and controls shift points with out clutch slippage.
[Re: MoparforLife]
#448885
08/25/09 05:29 PM
08/25/09 05:29 PM
Posts: 112 SK, Canada
etek
SK, Canada
SORRY GUYS!!! That's what I was always taught - my apolgies for bringing BAD info to the game!!! But my appreciation for the better info. Funny, becuause I knew it increased line pressure, but thought that's what held it in gear longer...isn't that what it would do in the end??
[Re: dOOc]
#448889
08/27/09 05:33 AM
08/27/09 05:33 AM
Posts: 401 Berlin, Germany
Flo
Berlin, Germany
If you drain the fluid... adjust the bands!
Just did the regular maintenance on my original 67 727, which started screwing up the 1-2 shifts. When I got the car someone had disengaged the linkage too, no idea how long it was run like that.
Adjusted the bands and the linkage, changed fluid and filter. Installed the smallest Transgo towing shift improver kit with conservative setting (drilled the holes to the medium size they suggested). Have a perfectly shifting transmission.
1967 Fury III 4door HT
tiny 318, late model roller block, bored and stroked to 344
