Re: Help. Cant get engine to stop missing :(
[Re: derekeh]
#448361
08/26/09 04:59 PM
08/26/09 04:59 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
you did that compression test with the carb at WOT, right?
the only reason I ask, is because the first time I did one, I didn't have the carb open, I saw one cylinder that had very low numbers and thought "crap" 2nd cylinder I thought "uh-oh..Im gonna have to rebuild this thing!" 3rd cylinder I thought "there's no way this engine would run on just 5 cylinders! I gotta be doing something wrong!"
did the test again and had pretty much 120 across the board
but, with numbers from 130-150, you probably had the throttle open, just thought I'd make sure!
**Photobucket sucks**
[Re: derekeh]
#448364
08/29/09 10:24 AM
08/29/09 10:24 AM
Posts: 21,123 Niles , Ohio
therocks
Niles , Ohio
What plugs and wires does it have?Its possible the wires might be bad.That or a small intake leak.Its possible a valve could be hanging or a lifter slightly collapsing.That might be the noise you are hearing.Rocky
Chrysler Firepower
[Re: RapidRobert]
#448365
08/29/09 12:09 PM
08/29/09 12:09 PM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
Its been converted to pretty much a stock electronic ignition setup.
I'd check rotor phasing ....
I'd sure consider reversing the two pickup coil wires, then resetting the timing. Been an occasional Mopar problem for 37 years.
Rick
[Re: MoparforLife]
#448368
08/29/09 10:12 PM
08/29/09 10:12 PM
Posts: 60 Sweet Home, Oregon
friesza
Sweet Home, Oregon
I have seen something similar to this on 3 different occasions....1) was a bad bad ballast resistor, 2) Was a failing ecu unit, and 3) was a friend who had an adjustable rocker not adjusted right and would miss at medium and up rpm range...hence a cam going flat or a bent pushrod...just my 2 cents...hope it helps
"Liberty is meaningless where the right to utter one's thoughts and opinions has ceased to exist. That, of all rights, is the dread of tyrants. It is the right which they first of all strike down."
Frederick Douglass
[Re: derekeh]
#448369
08/29/09 10:42 PM
08/29/09 10:42 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
I didnt think it would be the problem... but I took my carb apart and cleaned it all out. Didnt help with the problems any.
Stick you head over the carb and rev the engine up slowly until it starts missing. Check and see if fuel is dripping out of the boosters. This can cause a miss.
[Re: derekeh]
#448371
08/30/09 01:18 PM
08/30/09 01:18 PM
Posts: 316 Coolville, Ohio
Lew
Coolville, Ohio
this may be a no brainer but is there any chance that a plug wire could be jumping to a header tube, some of those cheapie headers dont give you much clearance for plug boots and you cant see it unless engine bay is dark, also check dist. cap for any unseeable cracks or carbon tracks. give motor some RPM to power up the spark when watching for spark to jump.
[Re: Lew]
#448372
08/30/09 01:27 PM
08/30/09 01:27 PM
Posts: 834 Beavercreek, Ohio
OA5599
Beavercreek, Ohio
[Re: friesza]
#448373
08/30/09 10:03 PM
08/30/09 10:03 PM
torkrules
I'm neurotic
I'm neurotic
Might want to wear a pare of safety glasses when doing that though....I know from experience...took a while to grow my left eyebrow back...lol
Good tip! Also, make sure everything is grounded properly (engine to fire wall, ignition box to chassis, voltage regulator to chassis, etc).
[Re: torkrules]
#448374
08/30/09 11:20 PM
08/30/09 11:20 PM
RapidRobert
I'd second what has been said. I'd take the carb top off & see if any globules of water in the bowl, rotor phasing, where's the timing at, intake leak, valve hanging up, secondary ign(plugs/wires/rotor/cap).
[Re: derekeh]
#448379
09/05/09 12:34 PM
09/05/09 12:34 PM
torkrules
I'm neurotic
I'm neurotic
I took the carb apart and cleaned it all out. It didnt help anything though. Ive not been able to locate a certain plug missing either... just seems random. It will idle okay now but the miss just comes at higher RPMs. Something else and I dont know if this means anything... but the exhaust note just doesnt sound right to me. Ive had low po 383s and 318s with this same exhaust and they sounded much better. This sounds very weak.
I should read through all of the post BUT, have you tried a different carb? Even though you cleaned it out, there may be some small particles caught in the emulsion tubes or the idle wells in the metering block. To get at these, you need to pull all of the plugs at the top of the metering blocks and pull all of the tubes out. This is not something for the faint of heart. Your better to try a different carb. If the problem clears, you can get another set of metering block.
[Re: torkrules]
#448380
09/05/09 02:01 PM
09/05/09 02:01 PM
torkrules
I'm neurotic
I'm neurotic
Also, how are the valve springs/valve seats? Any cam wear issues? Reluctor phasing?
