Re: Whats wrong with my engine? Vacuum readings and smoke
[Re: D_C]
#448202
08/24/09 06:00 PM
08/24/09 06:00 PM
Posts: 1,371 Costa Mesa, CA
chache876
Costa Mesa, CA
If it were just a vacuum leak the vacuum gauge would just read low wouldn't it?
I should also mention the exhaust does not smell like burning oil. I 'guess' it smells sweet, although I don't really go around huffing exhaust fumes so I can't be sure lol.
[Re: RodStRace]
#448204
08/24/09 06:13 PM
08/24/09 06:13 PM
chache876
Costa Mesa, CA
A bit of White at first startup may be condensation. Gas (HC) when burned (combined with oxygen or O2) forms CO2 (Carbon dioxide)and H2O (Water). with a cold exhaust, the steam of H2O cools enough to be seen.
The vacuum reading could be because multi-cylinder bikes use a carb for each cylinder, unlike cars. You will see a wild vacuum fluctuation.
Ok that makes sense with the vacuum gauge. Is there a way to use it to diagnose it like you would on a car with one carb? I've seen the motorcycle carb synchronization vacuum gauges, would I be able to just rig up something that would connect all four carbs into my single vacuum gauge?
[Re: Bill MeLater]
#448207
08/25/09 06:08 AM
08/25/09 06:08 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
You need to have a vacuum gage that balances all the cylinders for the reason mentioned.
[Re: moper]
#448208
08/25/09 07:48 AM
08/25/09 07:48 AM
Posts: 15,487 Florida
scratchnfotraction
![](/ubbthreads/images/graemlins/iagree.gif) a 4 gauge vac manifold to check a bike when hooked to all 4 carbs and running the vac reading with not fluctuate as much and you can sync all them together pull the plugs and take a look ![](/ubbthreads/images/graemlins/scope.gif) most likly valve seals how does it run/ride?? ![](/ubbthreads/images/graemlins/popcrn.gif)
