Re: My balancer spun about 8 degrees???? [Re: weedlayer] #446974
08/23/09 06:30 PM
08/23/09 06:30 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I've run the TCI rattler for years. No probs here either.
Re: My balancer spun about 8 degrees???? [Re: jinxy] #446975
08/24/09 07:24 AM
08/24/09 07:24 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I can't tell by looking at it, but you can when you put the timing light on it.
My Romac has two lines lasered on the front, one on the hub the other on the ring. If they're not lined up it's slipped.
Re: My balancer spun about 8 degrees???? [Re: jinxy] #446976
08/24/09 07:42 AM
08/24/09 07:42 AM
an8sec70cuda Offline
I have an ATI on my hemi and a Fluidamper on my wedge. No problems with either one. I had a BHJ once, it slipped not long after I put it on. CHIP
CHIP
'69 road runner, 440-6, 4 speed, Dana 60
'71 Demon 340, no drivetrain, on blocks behind the barn
'06 GMC 2500HD LBZ Duramax
Re: My balancer spun about 8 degrees???? [Re: an8sec70cuda] #446977
08/24/09 09:17 AM
08/24/09 09:17 AM
would that make the BHJ a
Big
Hunka
Junk
ATI makes a great product but they are a little pricey. there are other dampers out there that will do the job and hold up just fine for the average street/strip/bracket racer.
Re: My balancer spun about 8 degrees???? [Re: jinxy] #446978
08/24/09 09:21 AM
08/24/09 09:21 AM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
I use Pioneer SFI (look in Summit catalog) when I need an inexpensive SFI damper with Chrysler face. I've used them on 700+ HP motors with no issues.
I have ATI on the big $ stuff, they are great dampers but are overpiced IMO for all they really are. But with their bolt together design, they are virtually impossible to have "slip
like the cheaper pressed together dampers.
Re: My balancer spun about 8 degrees???? [Re: RyanJ] #446979
08/24/09 09:29 AM
08/24/09 09:29 AM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
Another advantage of the ATI is that you can ship it back to them for rebuild and recert for $90. I had my 1993 unit rebuilt in 2006.
Re: My balancer spun about 8 degrees???? [Re: cgall] #446980
08/24/09 01:02 PM
08/24/09 01:02 PM
Phoenix
jinxy Offline OP
jinxy  Offline OP
Phoenix
Both the ATI Super damper and the TCI Rattler seem good.
Will they work with the stock timing cover?
I also need to use the stock pulley for my alternator.
Any problems with this?
I'm getting mixed answers from their tech lines.
Jeff
p.s. the Romac that came off said SFI 18.1
It is a two piece unit that has spun.
Re: My balancer spun about 8 degrees???? [Re: jinxy] #446981
08/24/09 01:09 PM
08/24/09 01:09 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I know a fluid damper works with the stock timing cover. I would be 99.9999999% sure the others do too!
Re: My balancer spun about 8 degrees???? [Re: Dodgem] #446982
08/24/09 01:25 PM
08/24/09 01:25 PM
MG, Brazil
v8punch Offline
v8punch  Offline
MG, Brazil
My summit sfi sbf spun 90º in only 50 miles!!!!
Now I bougth an ATI.... beatiful piece!!! but i do not know how to disassemble it to match balance with my old summit(rip)....
Re: My balancer spun about 8 degrees???? [Re: v8punch] #446983
08/24/09 01:53 PM
08/24/09 01:53 PM
The ATI and the Fluidamper that I have are both on motors with stock timing covers. CHIP
CHIP
Re: My balancer spun about 8 degrees???? [Re: an8sec70cuda] #446984
08/24/09 08:44 PM
08/24/09 08:44 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Here is a pic of my summit Balancer. You can see by the blue line.how much it has moved.
Re: My balancer spun about 8 degrees???? [Re: Quicktree] #446985
08/24/09 09:06 PM
08/24/09 09:06 PM
OZ
CRIKEY Offline
super gas
CRIKEY  Offline
super gas
OZ
ROMAC has an indexing line from the inner to outer shell, have you checked it? Also your front pulley hasnt been pulled up hard on the outer rting at all has it??
I have been using ROMAC exsclusivly for over 15 yrs an am yet to have see any problems, IMO you should be looking at wot cause its failure.
FWIW I have used them on almost every racing application, DIRT CARS, DRAGS, CIRCUIT, ROAD & BOATS
ALSO ROMAC is SFI & its all but impossible for the outer ring to come off.
