Oil Pans Revisited #446767
08/23/09 08:35 AM
08/23/09 08:35 AM
Long Island, NY USA
BergmanAutoCraft Offline OP
Long Island, NY USA
Two oil pan questions:
1. What is the part number for a Magnum CAR oil pan?
2. Would there be any problem using this in an A body?
3. What type of baffling has proved effective with a 6,000 rpm stroker?
I've had a leaking POS Milodon for years, and would like to use the new style pan and gasket. I run 5.5 qts in the Milodon without issues as it is,as I found putting the prescibed 7 qts in that pan put the counterweights in the oil....
I'm all ears!
Re: Oil Pans Revisited [Re: BergmanAutoCraft] #446768
08/23/09 08:50 AM
08/23/09 08:50 AM
Michigan Troll
blk00rt Offline
blk00rt  Offline
Michigan Troll
I looked a couple months back for one and never found one. I ended up using just an old la oil pan and got it to seal up.
Rob Dunn
1976 Dart Sport 360
2000 dakota RT 408 with 150 nitrous
2013 Dodge Ram 1500 Hemi
2009 Jeep Patriot
Re: Oil Pans Revisited [Re: blk00rt] #446769
08/23/09 10:09 AM
08/23/09 10:09 AM
Long Island, NY USA
Long Island, NY USA
I'll find out from my dealer tomorrow. I'm thinking about using a Magnum car pan. I'm not sure if the MP one that is listed is an old or new style.
Re: Oil Pans Revisited [Re: BergmanAutoCraft] #446770
08/23/09 12:28 PM
08/23/09 12:28 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
There is no magnum car pan, they only came in trucks.
Use the LA 360 car pan.
Re: Oil Pans Revisited [Re: gdonovan] #446771
08/23/09 12:41 PM
08/23/09 12:41 PM
Long Island, NY USA
Long Island, NY USA
Thanks Gary, I just found that out...I am going to mod an LA pan for use with the one piece gasket. A little mod + RTV looks like it will work well.
Re: Oil Pans Revisited [Re: BergmanAutoCraft] #446772
08/23/09 12:44 PM
08/23/09 12:44 PM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
Kevko pan
Re: Oil Pans Revisited [Re: ThermoQuad] #446773
08/23/09 12:44 PM
08/23/09 12:44 PM
ThermoQuad Offline
ThermoQuad  Offline
another pic
Re: Oil Pans Revisited [Re: ThermoQuad] #446774
08/23/09 12:45 PM
08/23/09 12:45 PM
ThermoQuad Offline
ThermoQuad  Offline
another
Re: Oil Pans Revisited [Re: ThermoQuad] #446775
08/23/09 01:30 PM
08/23/09 01:30 PM
Long Island, NY USA
Long Island, NY USA
Had the Kevko and returned it. I wasn't happy with the construction quality. When side by side with the Milodon, it wasn't that much of a depth difference. Still sticks out of the K. Besides, it couldn't be installed with the motor in the car.
