How much front susp travel? #446066
08/22/09 02:04 PM
08/22/09 02:04 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
Duster 800hp trans brake ladder bar car.
Am doing a coil over conversion and think i bought too short shocks. Only 4" shock travel witch gives about 2" susp travel.
Should i get new longer ones or is it worth trying?
Re: How much front susp travel? [Re: sshemi] #446067
08/22/09 10:14 PM
08/22/09 10:14 PM
The first coil over ladder bar Duster I raced had a set of three inch travel AVO My new Duster has a set of Strange 7 inch travel coil over with a set of RJ ladder bars and a diagonal link It is a street and strip car so the chassis guy bought the longest ones he could for that reason It rides nice and leaves okay, 1:43 60 ft. best so far, 10:34 at 128.6 running out of fuel in high gear Faster sooner, see my post on the broken 8 3/4
Re: How much front susp travel? [Re: sshemi] #446068
08/22/09 10:23 PM
08/22/09 10:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
At least 6" of rear travel
EDIT
I just seen you said fronts... try for 5"
Re: How much front susp travel? [Re: MR_P_BODY] #446069
08/23/09 06:10 AM
08/23/09 06:10 AM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
EDIT
How much do you have?
I guess i can get the qa1s that have 5.3" of travel. these are the ones i have for the back.
If i go longer there is so much work involved that i could just put a strut front end on the car.
Re: How much front susp travel? [Re: sshemi] #446070
08/23/09 09:18 AM
08/23/09 09:18 AM
MR_P_BODY Offline
MR_P_BODY  Offline
EDIT
I run struts up front with 3" total travel
