318 X block #445392
08/21/09 07:10 PM
08/21/09 07:10 PM
Cincinnati OH
Bishop Offline OP
Bishop  Offline OP
Cincinnati OH
What are the cast # for a 318 X block and are they 2 block or 4 bolt mains? Are they any other differance than a standard small block by sight?
Thanks Brian
Re: 318 X block [Re: Bishop] #445393
08/21/09 07:56 PM
08/21/09 07:56 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
The one I had was a 4-bolt may have been converted. The main webs were thicker similar to the 340 TA blocks.
Leon
Re: 318 X block [Re: Bishop] #445394
08/21/09 07:56 PM
08/21/09 07:56 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
4104230-318 and there's a big "X" cast into the front of the block (Cylinder #2)
I think X-blocks only came in 2-bolt main but, could be wrong.
edit: Oh yeah, Leon......solid main webs and pan rails.
Re: 318 X block [Re: S/ST 3040] #445395
08/21/09 09:58 PM
08/21/09 09:58 PM
Lost in Pooler, GA
Gumbydammit Offline
Gumbydammit  Offline
Lost in Pooler, GA
I had a 67 or 68 318 truck motor that had an X cast into the block. I can't remember if it was on the front driver's side , or side of the block. The 318 X truck motor was the only small block to come from the factory with a full radius on the crank journals rather than the grooved journals like a conventional stock crank. I do not know if the block was any better than a standard or later 318, and I do not remember it being any different than a "stock" or standard production block. Alas, the crank had a bad thrust surface and was trashed.
I also had an early direct connection / mopar performance aftermarket X block. It was WAY heavier than a stock block. Filled pan rails and lower bore area are key ID areas. If I remember correctly, there was also a boss on the front driver's side that could be tapped to facilitate dry sump oiling.
I'm Gumby dammit!
Re: 318 X block [Re: Gumbydammit] #445396
08/21/09 10:50 PM
08/21/09 10:50 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
My X block isnt drilled for a dipstick tube but came with 2 bolt mains.
Re: 318 X block [Re: DavidDean] #445397
08/22/09 05:53 AM
08/22/09 05:53 AM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
pic
Re: 318 X block [Re: Scamp408] #445398
08/23/09 07:11 PM
08/23/09 07:11 PM
Cincinnati OH
Bishop Offline OP
Bishop  Offline OP
Cincinnati OH
Whay is the max size these things can be bore to? (I know you have to sonic check them be be 100%)
But what size (bore) where the designed for?
Thanks Brian
Re: 318 X block [Re: Bishop] #445399
08/23/09 07:34 PM
08/23/09 07:34 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
4.100-4.125 depending on sonic test
Re: 318 X block [Re: DavidDean] #445400
08/23/09 08:09 PM
08/23/09 08:09 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
yea my x block had a x on the pass.(#2) side and no dip stick hole.....
Re: 318 X block [Re: earthmover] #445401
08/23/09 08:14 PM
08/23/09 08:14 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
yep..everyone has it
Re: 318 X block [Re: quick77rt ] #445402
08/23/09 08:17 PM
08/23/09 08:17 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
4 bolter
Re: 318 X block [Re: quick77rt ] #445403
08/23/09 09:10 PM
08/23/09 09:10 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I dont have a picture right now but my X block has the X on the rear of the left bank and it is a 4 bolt block
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: 318 X block [Re: dusturbd340W5] #445404
08/23/09 09:40 PM
08/23/09 09:40 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
Im no Xpert (ha ha) but its my understanding the 5-79 blocks were all 2 bolters with the part number they were sold under, and the old book shows three main cap part numbers, one for two bolt caps and two part numbers for the 4 bolt caps.
The old book also said the X block 2 bolt main caps were of better stock then std caps, maybe that accounts for the two bolt cap part number.
Dont know how the foundry people really did the casting info but two of my blocks show only what looks like 15 minutes apart.
This is a bone stock nos 2 bolt X bottom, they are a fun peice to work with.
Re: 318 X block [Re: quick77rt ] #445405
08/24/09 04:24 PM
08/24/09 04:24 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
Also x on back
