Re: Foot brake racers
[Re: emarine01]
#445205
08/21/09 11:52 PM
08/21/09 11:52 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Here is how I used to launch a car on street tires that would spin if you nailed it at the line. I just power brake the car as much as it will take without moving and then just release the brake when you launch and dont move the gas until you start to move. Then ease the gas pedal down. It may take a few tries to nail it as the trick is give it as much gas as it will take without spinning the tires. Ron
[Re: 383man]
#445206
08/22/09 01:09 AM
08/22/09 01:09 AM
Posts: 123 Jefferson, OR
plumridiculous
Jefferson, OR
![](/ubbthreads/images/graemlins/iagree.gif) I launch my challenger the same way. I put as much rpm's as i can hold at the line and just release the brake and hit the gas after it starts rolling. I have 275 60's plain old BFG's. My car had a best of 12.05 at 116. It does take some practice and I will still spin once and while but you have to see what you can get away with.
Hope this Helps..George
[Re: emarine01]
#445210
08/22/09 12:47 PM
08/22/09 12:47 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I notice you mention "Truck". Weight bias in a pickup is not good, as almost no weight is over the rear end, so it will be tougher to get it to launch than with a car. If you have a vacuum secondary carb (which you should have with a truck and an automatic), try playing with the secondary springs. You can adjust the secondarys to come on slower, thus softening the hit at the line. Good luck.
[Re: StealthWedge67]
#445211
08/22/09 01:29 PM
08/22/09 01:29 PM
Posts: 2,530 PA
moparacer
PA
I always soften mine up with the converter.
The quickest 60ft converter is never the best bracket converter IMO.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: moparacer]
#445212
08/22/09 02:10 PM
08/22/09 02:10 PM
Posts: 3,695 nc
emarine01
nc
It is a 108 wheel base toyota 4x4 @ 3200 lbs, the weight is 70/30 with as much weight moved aft as possible, basically a 4 wheel drive lawn dart, If I stay in super stock I cant modify the fire wall to set back the engine witch it really needs, we hit hard enough to lift the front wheels around 4" for the first 30 or so ft, if it doesn't lift its so light you have no steering control till around 50 ft out, If you are not running straight on the launch its like playing billiards with the guardrail,, hitting the rail is not as bad as drag racing cause the tires act like big bumpers so the sheet metal doesn't get hurt, just tares up the outer lugs on the tires, A softer launch with better traction makes a lot more sense than the way I am doing it now for safety reasons but not sure about ET, the 2500 hp and up rails use a slipping clutch system that works good and the trucks like mine have all gone t brake with some kind of power limiting device 2 or 3 step on the msd, I have tried slower launches with less pedal and have always ran slower ET and very inconsistent
