Re: Cowl Hood Scoops.. Why on a MOPAR?????
[Re: colt340]
#44471
09/03/07 09:55 PM
09/03/07 09:55 PM
Didnt hurt my 60ft anyway...
[Re: 72chrgrally]
#44475
09/04/07 03:26 AM
09/04/07 03:26 AM
Posts: 2,933 Finalnd, Perkele
jyrki
Finalnd, Perkele
It's some seven years ago when I converted in the '66 GT Dart. To my surprise, the cowl induction blocked the visibility way more than the six pack it replaced. It's wide, and long, and equal height everywhere, my seats were installed pretty low in the car, and I couldn't see a whole lot out of there. As far as the looks go, at first I thought they were cool because you saw so few of them. Now, that they are everywhere, I don't like the looks a lot. Even though I have one in our car. Maybe it's time to convert to the good ol' L88 scoop?
Plynouth VIP '67 TT IC EFI
[Re: BILLYJAY]
#44476
09/04/07 09:03 AM
09/04/07 09:03 AM
Posts: 589 Indiana
YbNoRmAL
mopar addict
mopar addict
Indiana
[Re: YbNoRmAL]
#44477
09/04/07 10:04 AM
09/04/07 10:04 AM
I did it JUST to piss off the Mopar purists.. Really, I originally put it on for the Pump Gas Drags.. No forward facing scoops.
#44479
09/04/07 01:42 PM
09/04/07 01:42 PM
Posts: 1,522 Wisconsin
Garceau
Wisconsin
the original design of the cowl hood scoop was to direct cool air by picking it up from deflecting it off the windshield
And it does function fairly well. There is a high pressure area at the base of the windshield.
And to those that posted they went slower, have you given any consideration that the difference in air (be it less or more with the cowl hood) affected your a/f ratio at certain speeds?
Just a though.....
Cowl hoods DO FLOW AIR into the engine.
I dont like the looks either.
but if you study the various configurations and placement you will see that many are too far from the glass to catch the air and let the scoop do it's job.
FINALLY - many cowl scoops are not set up correctly. I know mine isnt, I bought it like that, even though mine is an adaption of the original cowl type on the Daytonas its still not close enough to the windshield to function properly.
Also a cowl scoop is more consistent, and easier to see around.
Many scoops on many race cars do very little, they catch very little air and do nothing more than give hood clearance.
They say if you take a string from the front of your hood to your windshield, if your scoop isnt above it, its benefits are very slim.
[Re: ram87]
#44481
09/04/07 05:33 PM
09/04/07 05:33 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
I thought that is what was wrong with my cowl. Too close to the windsheild. My carb starves for air after the 1000ft.
[Re: Leon441]
#44482
09/04/07 05:59 PM
09/04/07 05:59 PM
Garceau
Wisconsin
Most are too far away from the windshield, there is a formula out there somewhere.
But I heard it has to be pretty tight to the windshield to be of effective use....
Post deleted by Defbob
[Re: Leon441]
#44483
09/04/07 06:02 PM
09/04/07 06:02 PM
#44484
09/04/07 06:06 PM
09/04/07 06:06 PM
Posts: 2,117 Cleveland Ohio
10secGTX
Cleveland Ohio
I think if done correctly the cowl hood flows with the car no matter what make or model.. for example the Blue Super Bee with the black cowl...GOOD The green Valiant with the 14" Cowl....BAD my
[Re: Garceau]
#44485
09/04/07 06:12 PM
09/04/07 06:12 PM
#44486
09/04/07 06:35 PM
09/04/07 06:35 PM
why not seal the carb to an under the bumper scoop and use the cowl to let hot engine compartment air out.
