I redid the dash layout and put the two gauges that were in the center console with the others in the dash and moved the tach to the top of the dash. What do ya'll think.
I have a problem with the turn signal indicator lights though. When you mash the brake pedal they light up.
I'm also still working on the switch panel for the headlights, fans and pumps. When I activate the fuel pump relay by connecting a power wire to the wire that runs to the relay the high beam indicator light flickers.
All the indicator lights are leds, could it be they need some kind resistor in the power wire to them? Any ideas?
