Re: Brighter dash cluster lamps or white LED's? [Re: FrankenScamp] #441795
09/06/09 01:01 AM
09/06/09 01:01 AM
I tried to paste? the thread but I dont have the computer savvy to do so. Go back to Tues Aug 18 @6:44AM for the thread "brighter dash cluster lamps or white LED's" EDIT this is the thread
Re: Brighter dash cluster lamps or white LED's? [Re: moparcanuk] #441796
09/06/09 08:31 AM
09/06/09 08:31 AM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
The Sylvania site has this for the instrument lights on a 69 GTX:
Instrument-general
1893
194
53
57
So which ones do I use on my instrument panel?
Well the GTX of that year uses the #57 which is a brass base bulb with push and turn bayonet lugs.
My Duster has the "grain of wheat" all glass bulb which just pushes in the socket.
I'll try to dig up the paperwork on the bulbs today and post the info.
I'll note though I do not like how hot the headlamp switch gets running the new dash bulbs and will look into the cooler LED's when time permits.
Re: Brighter dash cluster lamps or white LED's? [Re: gdonovan] #441797
09/10/09 05:54 PM
09/10/09 05:54 PM
Auburn Hills, Michigan
K
kieron_kohlmann Offline
K
i just bought 2 of each of the following for my bee. I wanted to see how they work/look before i spend $30 some $ on new bulbs. my opinion is they are amazing! even with one bulb it lights up a ton! i just ordered the rest to complete my guage cluster
links
http://cgi.ebay.com/ebaymotors/ws/eBayIS...T#ht_1642wt_913
http://cgi.ebay.com/ebaymotors/ws/eBayIS...T#ht_1741wt_959
Re: Brighter dash cluster lamps or white LED's? [Re: kieron_kohlmann] #441798
09/10/09 06:24 PM
09/10/09 06:24 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
I am watching this thread. Are those bulbs cooler that the stock ones? I am worried about them melting or over heating the back of the instrument cluster.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Brighter dash cluster lamps or white LED's? [Re: gdonovan] #441799
09/10/09 07:28 PM
09/10/09 07:28 PM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
Stock size is 194 which is 4-5 watts
908 is next brightest
The 908 is 9 watts I believe. I didn't want to go that high with the stock system so I went with 168's - they are a watt or watt and a half higher than the 194. Not a lot brighter, but brighter.
Ride eternal, shiny and chrome
Re: Brighter dash cluster lamps or white LED's? [Re: ChickMaggot] #441800
09/11/09 02:14 AM
09/11/09 02:14 AM
Vista, California
ChickMaggot Offline
ChickMaggot  Offline
Vista, California
What brand are the 221's you found.
I'll dig up the info for you.
Any update on a brand name?
I still haven't been able to find any
Any luck?
You can lead a gift horse to water, but you
can't look in his mouth.
Re: Brighter dash cluster lamps or white LED's? [Re: ChickMaggot] #441801
09/22/09 01:56 AM
09/22/09 01:56 AM
Vista, California
ChickMaggot Offline
ChickMaggot  Offline
Vista, California
Any luck?
Still hoping you'll help a brutha out with some info.
