LA to MAGNUM swap - tranny question
#441366
08/17/09 10:00 PM
08/17/09 10:00 PM
Posts: 571 central PA
mopartial
central PA
Im considering getting a mid 90's Mag for my 75 Scamp. I have a mid 70's 727 in storage. Should I expect to use this or would entire Magnum drivetrain (engine + tranny) swap in?
Thanks.
If it aint broke, dont break it.
Re: LA to MAGNUM swap - tranny question
[Re: mopartial]
#441367
08/18/09 06:06 AM
08/18/09 06:06 AM
mopartial
central PA
BTT
Por favor...This should be easy for you guys...
[Re: mopartial]
#441368
08/18/09 06:35 AM
08/18/09 06:35 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
it'll bolt up, work fine.
the OD tranny won't fit an A body with extensive floorpan/crossmember mods.
[Re: 727jim]
#441370
08/18/09 12:00 PM
08/18/09 12:00 PM
Posts: 1,325 Orlando Fl
Dos Snails
Orlando Fl
u will need to notch the r/s of the 727 case to clarence the crank sensor.
Only if you plan on using the stock Magnum efi electronics. If using a carb then no need for the sensor...
[Re: Dos Snails]
#441371
08/18/09 02:55 PM
08/18/09 02:55 PM
Posts: 1,086 Baton Rouge, La.
StandOnIt
Baton Rouge, La.
I used my stock 904 behind a 98 5.9 with a B&M flexplate. I put a carb so no notching the bellhousing for anything. Also, use the small starter. Oh yeah, I have a volare so its just about the same as an A body underthere.
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
[Re: StandOnIt]
#441372
08/18/09 07:21 PM
08/18/09 07:21 PM
Posts: 554 Mesa , Az
Jambbii
Mesa , Az
The converter also needs to be rebalanced for a magnum motor also. I have used the MP kit.
70 Challenger 1960 Town Wagon P Pump 24v cummins project 06 Mega 3500 Drw 2wd 12 Durango R/T 18 Power Wagon 67 A100
