Can U use a crossram manifold on Eddy heads? #440906
08/17/09 02:00 PM
08/17/09 02:00 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
If I recall correctly you cant?
I have a 500 stroker sitting here done with eddy heads, approx 600 Hp, maybe a bit more, 10.5.1 and was for the LAWFISH car. I dont have time to race with this new job and hate looking at this motor sitting here.
I want a 64 Polara or even a 63 polara or Fury, max wedge era looking car. But if I recall correctly, I cant use the crossram manifold in take with these heads????
curious
Re: Can U use a crossram manifold on Eddy heads? [Re: RUMBLON] #440907
08/17/09 02:01 PM
08/17/09 02:01 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
this is t. needs to be painted and its almost done.
Re: Can U use a crossram manifold on Eddy heads? [Re: RUMBLON] #440908
08/17/09 02:08 PM
08/17/09 02:08 PM
AndyF Offline
AndyF  Offline
There is a cross ram casting for the smaller standard port heads. Call Mancini Racing, they have them in stock. I'd recommend a couple of smaller Edelbrock carbs to go with it, maybe even the little 500 cfm #1804 carbs.
Re: Can U use a crossram manifold on Eddy heads? [Re: AndyF] #440909
08/17/09 03:11 PM
08/17/09 03:11 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Re: Can U use a crossram manifold on Eddy heads? [Re: RUMBLON] #440910
08/17/09 03:37 PM
08/17/09 03:37 PM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
yes you can , im running a set of eddy victor 440 max heads on my 500 stroker with a 63 stage II cross ram and m/w exhaust manifolds and two holley 600,s on my 62 dart m/w clone, the bad thing about these heads are that they sit up high and makes it necasary to use a hood scoop for hood /carb clearance.
Re: Can U use a crossram manifold on Eddy heads? [Re: moparsquid] #440911
08/17/09 05:09 PM
08/17/09 05:09 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
Thanks guys, now all I need is a 63 64 era mopar to put this motor in. what does a set of carb cost?
I am grabbing this on the 1st to keep in case I find a damaged shell.
Re: Can U use a crossram manifold on Eddy heads? [Re: RUMBLON] #440912
08/17/09 05:35 PM
08/17/09 05:35 PM
Chesapeake Va
BobK Offline
BobK  Offline
Chesapeake Va
440, Eddy heads ported to Max Wedge size, M.W. intake. Is this what you are asking about?
1964 Plymouth Fury x 2
1964 Plymouth Sport Fury
Re: Can U use a crossram manifold on Eddy heads? [Re: BobK] #440913
08/17/09 06:50 PM
08/17/09 06:50 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I dont think his Eddy heads are ported to Max Wedge size. He wants a crossram to fit standard port or stock ports on the Eddy's which you can get from Mancini and also A & A I think. Ron
Re: Can U use a crossram manifold on Eddy heads? [Re: 383man] #440914
08/18/09 04:53 AM
08/18/09 04:53 AM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
Yes, thanks for the info guys. iTS GREATLY APPRECIATED
dAVE
