Re: Read my spark plug [pics] [Re: 68roadrunner] #438803
08/16/09 08:27 AM
08/16/09 08:27 AM
Wisconsin
Garceau Offline
Garceau  Offline
Wisconsin
Ok so after reading all 3 links...the first link says ground strap shows heat range and the other 2 links say it shows timing...so which is it?
This is the internet... you might get some more ideas
BUT I've use the strap as a timing indicator... as
in the link I posted
i also use the stap to check timing. on gas that is. iam getting ready to run my fist alky motor, how will this affect it?
Alky makes it harder to read, it will burn considerably cleaner because it doesnt have any additives in it. I run NGKs with alky and many use the threads to judge it. You will have to google it up and see what I mean, cant think how to explain it right now.
Re: Read my spark plug [pics] [Re: pacifica] #438804
08/16/09 10:35 AM
08/16/09 10:35 AM
old westchester
mcat4321 Offline
mcat4321  Offline
old westchester
i would guess you are running an octane booster by the color, it looks alittle fat to me.. plus the tip of the strap looks like it is hot, maybe try a cooler plug. the timing mark on the strap should be right on the arch/bend and i would say your valve seals are going ..but im prolly wrong
Re: Read my spark plug [pics] [Re: mcat4321] #438805
08/16/09 10:50 AM
08/16/09 10:50 AM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
LOOKS LIKE OIL TO ME
Re: Read my spark plug [pics] [Re: B1KILLER] #438806
08/16/09 11:25 AM
08/16/09 11:25 AM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
the fact that it has 2K mile on it is a joke.the oil could be just from startup too rich or like said valve seals going...put some fresh plugs in it and check it a few times.
Re: Read my spark plug [pics] [Re: B1KILLER] #438807
08/16/09 11:32 AM
08/16/09 11:32 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
That looks a hair too juicy on the flat,
Re: Read my spark plug [pics] [Re: blownzoom440] #438808
08/16/09 01:09 PM
08/16/09 01:09 PM
N.E.Ohio
P
pacifica Offline OP
pacifica  Offline OP
P
N.E.Ohio
Sorry to all. I should have done some reading before I posted pics.
I will get NEW plugs and go racing Wednesday
Also the oil on the plugs is misleading because it gets on the threads and circle as I pull it out.
Re: Read my spark plug [pics] [Re: pacifica] #438809
08/16/09 01:22 PM
08/16/09 01:22 PM
ELYRIA,OH
ELYRIA,OH
get out and enjoy! we look forward to the fresh plug pics. what brank and # plugs are those?
Re: Read my spark plug [pics] [Re: blownzoom440] #438810
08/16/09 01:40 PM
08/16/09 01:40 PM
N.E.Ohio
P
pacifica Offline OP
pacifica  Offline OP
P
N.E.Ohio
Autolite 65 .....
I am sure to get now
