Re: Tips for installing trunk seal 68' fastback barracuda
[Re: moparmatt]
#438394
08/14/09 11:37 PM
08/14/09 11:37 PM
RapidRobert
use the 3M yellow weathertrip adhesive as it dries hard in seconds and have a helper to aid w positioning as it's almost like contact cement, when it touches that's pretty much where it is at & you have 1 or 2 seconds to get it right. EDIT have him inside the trunk running a glue line on the bottom side of the weatherstripping while you on the outside of the trunk position/lay in place the weatherstrip then when done shut the trunk & let it setup overnight
[Re: moparmatt]
#438395
08/15/09 11:02 AM
08/15/09 11:02 AM
Posts: 6,167 Maryland
GO_Fish
Maryland
I used the 3M adhesive. Had a mess of clothes pins on hand, and pinned the weatherstrip in place as I went. After 10 or 15 minutes I removed the clothes pins and shut the trunk. Stayed in place very well.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: moparmatt]
#438398
08/15/09 12:30 PM
08/15/09 12:30 PM
RapidRobert
I'm missing something here. I just started at a random point & glued it down & worked my way around & when I got back to my starting point I just trimmed the extra several inches off & with the ends touching, glued it in place. There was nothing to stretch.
[Re: moparmatt]
#438400
08/15/09 03:56 PM
08/15/09 03:56 PM
RapidRobert
I've been trying to remember that for the last hour as I figured that would help & I'm thinking soffseal(sp) but I'm not sure.
[Re: moparmatt]
#438402
08/15/09 04:17 PM
08/15/09 04:17 PM
RapidRobert
that is strange & we're still missing something as it is not like an O ring that needs to be stretched over something, it just glued down easily & several minutes later I shut the trunk for the night & the next day it was indented slightly on top showing a perfect seal.
