Re: another HHR fan question A Bodies ONLY
[Re: bigtimeauto]
#437036
08/15/09 10:18 PM
08/15/09 10:18 PM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
Am I the only one who mounted my rad in front of the core support?
Maybe
Do you have any pics of that area? How big a radiator? What did you have to cut or remove to get it in there?
thanks -Charles
[Re: DrCharles]
#437037
08/15/09 10:20 PM
08/15/09 10:20 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
I'll take soome pics tomorrow. One thing is you need a glass hood because i did remove the latch.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Post deleted by Defbob
[Re: 1_WILD_RT]
#437039
08/16/09 11:07 PM
08/16/09 11:07 PM
[Re: 493_DART]
#437042
08/18/09 11:03 PM
08/18/09 11:03 PM
DrCharles
West Plains, MO
That 1/4" clearance is with your radiator in the stock position (no cutting of the core support)? hmmm won't work so good with a 3/8" motor plate... Wonder what it would cost to have 3/8" milled off my WP housing to compensate for it? I'd definitely like to see pics though -Charles
[Re: DrCharles]
#437043
08/19/09 12:55 AM
08/19/09 12:55 AM
Posts: 4,384 Worst Weather USA
493_DART
Worst Weather USA
-Charles
Here's where I'm at as of tonight---
I cut some of the rad support out and set the rad/fan in there . Now Ive got around 3/4" clearance - looks pretty good in there now
Im going to start making brackets tomorrow night , should have it all done some time Thursday - I will definitely post some pics .
[Re: moparniac]
#437045
08/19/09 04:53 PM
08/19/09 04:53 PM
Posts: 498 El Dorado Ca
65signet
El Dorado Ca
I am also thinking of using that fan and would like to see pics, but it sounds like you cannot leave the radiator in the stock position?
1965 Plymouth Barracuda 273 M/SA 1970 Plymouth Duster 360/904 10.60s with J heads
[Re: 65signet]
#437046
08/19/09 06:05 PM
08/19/09 06:05 PM
493_DART
Worst Weather USA
You "could" ...
but you would have to either 1. run an electric pump 2. use some shallow head bolts for the pulley (kinda like converter bolts) ?
it would still be close ....
[Re: 493_DART]
#437047
08/19/09 06:10 PM
08/19/09 06:10 PM
Posts: 3,210 robin hood country
deaks
robin hood country
I moved mine forward and also fitted a larger 31" rad at the same time. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: deaks]
#437050
08/20/09 03:35 PM
08/20/09 03:35 PM
65signet
El Dorado Ca
How did you move the radiator forward did you cut the support?
[Re: 65signet]
#437051
08/20/09 03:46 PM
08/20/09 03:46 PM
deaks
robin hood country
You have to trim the top edge and the sides to let the rad into the panel so that the rad sits tight to the upright of the front panel. Here's a pic of one that's done
[Re: 493_DART]
#437054
08/20/09 04:03 PM
08/20/09 04:03 PM
deaks
robin hood country
Sorry, that's not mine it's a guy over here, i've got the one with the spring inside and it works a treat. Mick
