Page 1 of 5 1 2 3 4 5
another HHR fan question A Bodies ONLY #436996
08/13/09 05:12 PM
08/13/09 05:12 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
Has anyone fit the HHR fan in a Big block A body ?
If so--give details
Re: another HHR fan question A Bodies ONLY [Re: 493_DART] #436997
08/13/09 05:18 PM
08/13/09 05:18 PM
Jacksonville, NC
RonP Offline
RonP  Offline
Jacksonville, NC
One of the best things I have done. I did have to trim the support both side to side and the amll lip at the top the goes toward the rear of the car. I had to do that to move the Rad/fan combo forward so it didn't hit the WP. Took all of 10 minutes and then made some mounts and has been great.
Re: another HHR fan question A Bodies ONLY [Re: 493_DART] #436998
08/13/09 05:20 PM
08/13/09 05:20 PM
Ames, Iowa
LoneMopar Offline
LoneMopar  Offline
Ames, Iowa
Bring it over to the shop.
I have the tool to make it fit!
Re: another HHR fan question A Bodies ONLY [Re: LoneMopar] #436999
08/13/09 05:51 PM
08/13/09 05:51 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
ok Ron- im not afraid to do any "trimming" , seems like it would only need moved maybe 1/2" ?
wondering if anyone has fit this fan on the front side?
Steve , i already have that special tool
Re: another HHR fan question A Bodies ONLY [Re: 493_DART] #437000
08/13/09 06:13 PM
08/13/09 06:13 PM
Oh
His and Her 69's Offline
Oh
I have the fan on the front side of my radiator and it is a pusher now.
It works Great and fit in the space with only little mods done.
This is on a B body though.
Re: another HHR fan question A Bodies ONLY [Re: His and Her 69's] #437001
08/13/09 06:56 PM
08/13/09 06:56 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
wonder how the fit would be with a drop in WP unit....
Mopar Performance
Re: another HHR fan question A Bodies ONLY [Re: 493_DART] #437002
08/13/09 07:22 PM
08/13/09 07:22 PM
NC
440Jim Offline
440Jim  Offline
NC
How many amps does it draw?
I like the built in fan shround to the radiator edges.
Re: another HHR fan question A Bodies ONLY [Re: 440Jim] #437003
08/13/09 07:39 PM
08/13/09 07:39 PM
Jacksonville, NC
RonP Offline
RonP  Offline
Jacksonville, NC
I will look through my notes as I know I checked it and if not, I will tomorrow after work. The thing moves a ton of air and is so quiet.
Re: another HHR fan question A Bodies ONLY [Re: 493_DART] #437004
08/13/09 09:42 PM
08/13/09 09:42 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
Has anyone used one on the aluminum downflow radiators? I am curious as to how they fit!?!
Re: another HHR fan question A Bodies ONLY [Re: RonP] #437005
08/13/09 10:52 PM
08/13/09 10:52 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
I hope my stock style alt. will be enough
the only other thing it runs is my 7 amp fuel pump
Re: another HHR fan question A Bodies ONLY [Re: 493_DART] #437006
08/13/09 11:34 PM
08/13/09 11:34 PM
Newfoundland
codfish Offline
codfish  Offline
Newfoundland
I'm watching this with great interest.
I only have about 2 5/8" between my rad, and my MECHANICAL waterpump.
Anyone fit one in an A-body with a mechanical wp?
codfish
Re: another HHR fan question A Bodies ONLY [Re: RonP] #437007
08/13/09 11:40 PM
08/13/09 11:40 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I love mine also.
Re: another HHR fan question A Bodies ONLY [Re: ProSport] #437008
08/14/09 12:33 AM
08/14/09 12:33 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
ProSport--
looks like you moved the rad forward a little ? how much ?
i have a stock style water pump also Codfish.....
Im gonna make this damn thing fit........yes i broke out the credit card tonight and ordered...... $60.75 to my door
Re: another HHR fan question A Bodies ONLY [Re: 493_DART] #437009
08/14/09 06:35 AM
08/14/09 06:35 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
How many cfm of air does that thing flow.... 493dart where did you order yours from.. thx
Mopar Performance
Re: another HHR fan question A Bodies ONLY [Re: moparniac] #437010
08/14/09 07:26 AM
08/14/09 07:26 AM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
I have one on my 94 and love it. Cools in the Hot Houston Summer Heat! And it is pretty quiet too!
I got mine from Rock Auto (online) for about $55 shipped.
Re: another HHR fan question A Bodies ONLY [Re: moparniac] #437011
08/14/09 01:04 PM
08/14/09 01:04 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
i heard 3000 at least .
rockauto.com $60 shipped
Re: another HHR fan question A Bodies ONLY [Re: 493_DART] #437012
08/14/09 01:15 PM
08/14/09 01:15 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
A word to the wise, i was given by a member here. With anything close to a stock charging system , the HHR fan will flat eat up a battery in a mighty short time.
A guy told me he had a 50 amp denso on his car and with that fan, ran out of juice on a sortie on the street one night because of how much juice that HHR eats. That is the only reason i dont currently have one, and just bought a much lower amP draw new fan for my car....aa i have a stock alt, not even as good as his Denso that didnt cut the mustard.
Your results may vary
418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car
1.41 best 60 foot
6.54 @ 105.20
Re: another HHR fan question A Bodies ONLY [Re: B3422W5] #437013
08/14/09 01:22 PM
08/14/09 01:22 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
i was thinking that... however i only run a 7 amp pump , never street drive with the lights on anymore.
any ALT recommendations ? oem junkyard preffered ....
Re: another HHR fan question A Bodies ONLY [Re: B3422W5] #437014
08/14/09 01:27 PM
08/14/09 01:27 PM
Jacksonville, NC
RonP Offline
RonP  Offline
Jacksonville, NC
I don't have a stock alt, but I am going to measure the draw tonight when I get off work. if I remember correctly it drew way less power than most previous fans I have had. Also, since the swap I have noticed zero difference in battery charging or anything electrical related. as mentioned though, like everything on here, your results may vary.
Re: another HHR fan question A Bodies ONLY [Re: RonP] #437015
08/14/09 02:47 PM
08/14/09 02:47 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
It pulls about 30 amps at startup and 13 amps running
