Page 2 of 3 1 2 3
Re: P5 heads [Re: Scamp451] #436715
08/14/09 11:56 AM
08/14/09 11:56 AM
ohio
HEMIDARTS Offline
HEMIDARTS  Offline
ohio
Wow Scamp, that is just freakin wild!!!
Re: P5 heads [Re: HEMIDARTS] #436716
08/14/09 12:01 PM
08/14/09 12:01 PM
Mcallen, TX
SB449VALIANT Offline
Mcallen, TX
sb hemi quattro..
Re: P5 heads [Re: Diablo] #436717
08/14/09 12:10 PM
08/14/09 12:10 PM
Manassas, VA USA
Scamp451 Offline OP
Scamp451  Offline OP
Manassas, VA USA
So what do they flow??? How big of an intake valve is in them???
Good question. As I learn a little more about cylinder heads, I would be curious to see what the runner looks like, the P7's look to be about 2-3 feet long!
P5- 10° intake, 2° exhaust valve angles, and use a 5/16" stem based on the literature I found.
I had read or heard somewhere that they were trying to run a Hemi head when they were getting back in NASCAR, and NASCAR not only said NO but H*** NO! Perhaps that is how the P7 was developed? I know there are some on this board that know alot more about it than me.
This is the only stock photo I could find of the P5's.
"Starting" with a 8.600" deck height, the rod must be the length of a 289 Ford or something, even with a 3.150" stoke? I guess they were bread to sing, rather than grunt.
Re: P5 heads [Re: LA360] #436718
08/16/09 01:49 AM
08/16/09 01:49 AM
Seattle WA
RichV Offline
RichV  Offline
Seattle WA
From one of Zippy's earlier post.
"That would be P5007151AC which is marketed as an R4 block machined for use with P5 heads. As of today there are 7 of them in Mopar's national stock."
I think the XR guys thought they could machine a block that would work with P5s.
Re: P5 heads [Re: RichV] #436719
08/17/09 07:15 AM
08/17/09 07:15 AM
Manassas, VA USA
Scamp451 Offline OP
Scamp451  Offline OP
Manassas, VA USA
So if I am reading your post correctly, ONLY the R4 will accept these heads. I thought that one of the XR's would be able to accept the P5's, but I guess not. I saw an R4 on junk recently, not sure if it is still there.
The R4 has a dual tappet angle which is interesting 48 in. 59 ex. No provision for internal wet sump or factory stype distributor.
Not sure how old that earlier post is, but would also be curious to see if any heads show up on the locator?
Re: P5 heads [Re: Scamp451] #436720
08/17/09 07:47 AM
08/17/09 07:47 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
There were 2 versions of the R-4 block........one for the P-5
head (48º/59º tappet) and one for the wedge. (straight 48º)
Gilberto posted the 4 cylinder block that used a single P-5 HEMI
head. There was a Comp Eliminator @ INDY several years ago
that ran that......but, assume you meant a V-8 block.
Re: P5 heads [Re: Scamp451] #436721
08/18/09 10:13 PM
08/18/09 10:13 PM
Dyno
JSL Offline
JSL  Offline
Dyno
Here is another pic!
Re: P5 heads [Re: JSL] #436722
08/19/09 09:38 AM
08/19/09 09:38 AM
Manassas, VA USA
Scamp451 Offline OP
Scamp451  Offline OP
Manassas, VA USA
Is this the car?
Re: P5 heads [Re: Scamp451] #436723
10/10/10 07:49 AM
10/10/10 07:49 AM
S/ST 3040 Offline
S/ST 3040  Offline
Any more pictures/info?
Re: P5 heads [Re: S/ST 3040] #436724
10/10/10 10:09 AM
10/10/10 10:09 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Re: P5 heads [Re: Dragula] #436725
10/10/10 10:34 AM
10/10/10 10:34 AM
ohio
HEMIDARTS Offline
HEMIDARTS  Offline
ohio
Thanks for posting that Dragula!!!
Man i wish i would have bought one of those trucks instead of my Arrow.
Re: P5 heads [Re: HEMIDARTS] #436726
10/10/10 11:46 AM
10/10/10 11:46 AM
Finland
mafo Offline
mafo  Offline
Finland
interesting topic...
I was thinking about a r3 block without lifter holes then you can make it fit and get those cubes
however many of the p5 castings were crap, I was offered to buy 2 pairs with intakes and hardware for a very god price but the seller advised against me buying !!, because of water leaks and other problems
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: P5 heads [Re: mafo] #436727
10/10/10 03:45 PM
10/10/10 03:45 PM
Finland
mafo Offline
mafo  Offline
Finland
Re: P5 heads [Re: mafo] #436728
10/10/10 06:26 PM
10/10/10 06:26 PM
Charleston, SC
SCDaytona Offline
SCDaytona  Offline
Charleston, SC
Scott Gove runs one in his SS/AM car and he said it wasn't much better than his W8 motor.
Re: P5 heads [Re: Scamp451] #436729
10/11/10 06:05 PM
10/11/10 06:05 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
As I mingle amongst the small block community, I am constantly learning something new which also raises more questions. One question that pops into my head once in a while that I always forget to ask about in conversation is about the P5 heads.
I understand they succeeded the W8's for the PS trucks. After that did Mopar just kill that engine program altogether? Curious as to why. Looks like a pretty mean top end. I know if one car that has one on an 4 cyl. in NHRA, and I guess maybe some dirt/circle 4 cyl. motors still run them, but not exactly sure.
I see the P7's for sale quite frequently, but never the P5's on any drag cars, or for sale.
...This one was for sale here on Moparts & Race Junk in Feb 06 till it fell off the page with no responses. It was the 1st Gen P5 before the plug relocation (P5 HEMI).
Re: P5 heads [Re: thehemikid] #436730
10/11/10 11:19 PM
10/11/10 11:19 PM
Down South
DaKuda Offline
DaKuda  Offline
Down South
What makes them a HEMI?? Am I looking at the combustion chamber correctly?
Re: P5 heads [Re: DaKuda] #436731
10/12/10 01:39 AM
10/12/10 01:39 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
The marketing department.
Plynouth VIP '67 TT IC EFI
Re: P5 heads [Re: DaKuda] #436732
10/12/10 02:52 AM
10/12/10 02:52 AM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
...They're closer to a polysphere, & similar to the Fueling.
...You can see the open area's where the next design (Hemi) spark plug's were relocated. This was an X-David Nickens P5 358ci.
Re: P5 heads [Re: thehemikid] #436733
10/12/10 09:03 PM
10/12/10 09:03 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
The P5 heads shown were considered to be the "Wedge" heads, when the plugs went through the Rocker covers, they started with the Hemi marketing. At the end of the day they are just a Splayed valve wedge head, like the Hemi 99 heads.
Alan Jones
Re: P5 heads [Re: LA360] #436734
10/12/10 11:31 PM
10/12/10 11:31 PM
Down South
DaKuda Offline
DaKuda  Offline
Down South
Nothing HEMI about what I see except the word on the valve covers.
Page 2 of 3 1 2 3
