Re: radio delete question [Re: Dave Watt] #436268
08/13/09 05:56 PM
08/13/09 05:56 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
Or how about a steam roller, it's not rolling steam. Or a steam iron, you're not ironing steam.
Re: radio delete question [Re: Kidsixpack] #436269
08/13/09 06:15 PM
08/13/09 06:15 PM
Anonymous OP
Anonymous OP
Thanks for answering my question. Thanks to the mice we don't have the broadcast sheet, but do have the window sticker. It doesn't list a radio, so I knew it didn't come with a radio. I was unsure about the hole in the fender though.
By the way it is WM21M9AXXXXXX, V2, black interior, bench seat, 4 speed car and rusty.
Thanks for clearing it up.
Mark
Re: radio delete question [Re: Kidsixpack] #436270
08/13/09 08:08 PM
08/13/09 08:08 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I have a 6 pack bee that is a radio delete car that had an am/8 track with 4 chrysler speekers installed when new. My uncle purchased it new and the radio and speekers had already been installed. The fender has been replaced long ago and my uncle has passed away. My question is did a radio delete car come with a fender with a hole and a rubber plug or a fender without a hole. THANKS for our help!
See ya
Mark
Mark, don't let any of these comments upset you. It is commonly called "radio delete" when there is no radio ordered for the car. It has been and always will be called "radio delete". There is no antenna hole in the front fender if a radio was not ordered. There would be a textured plastic "block-off" trim panel in the dash and a very thin black cardboard blockoff taped with wide black masking tape to the underneath of the dash to cover the center speaker grill opening. This is to keep the light from shining up through the dash. I believe the only way to tell for sure that it was ordered without a radio on a Lynch Road car is if you have the broadcast sheet or the dealer's bill of sale from when the car was purchased? If you can show that the 8-track was a dealer installed item when new, I'd leave it in...unless it's a 4 speed coupe.
Agreed! My car is "Radio Delete" I can't believe people still bring this crap up. There are three people in the hobby that don't call it radio delete and their all on this forum! (they really need to get a life)!
KID
I do it mostly because it's funny to see how far up your butt your panties get whenever it's mentioned ...
Re: radio delete question [Re: JohnRR] #436271
08/13/09 08:14 PM
08/13/09 08:14 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
See ya
Mark
KID
Re: radio delete question [Re: Dave Watt] #436272
08/14/09 11:36 AM
08/14/09 11:36 AM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
What really bugs me is when people talk about their hot water heater. Why would you be heating hot water?
Actually, when I first installed the device-that-heats-water in my home, it was shipped empty. Once I installed it, I filled it for the first time with cold water, and it heated that cold water up to thermostat temperature. In my memory, that was the last time it was a [cold] water heater. Ever since then, the thermostat setting has kicked the burners on as soon as the stored water dropped below the setting on the dial. Like the majority of people with tanked water heaters, this thermostat setting is not cold, cool, or even warm. The threshold is set at slightly-less-hot-than-I-want-my-hot-water-to-be.
My house DOES have a "hot water heater".
HOW COOL IS THAT!?
Down to just a blue car now.
Re: radio delete question [Re: Dave Watt] #2711606
10/31/19 01:05 PM
10/31/19 01:05 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
Resurrecting a very old post.,,,,,
Would the radio delete E Bodies have a deleted hole on the fenders skin as well as on the fender underbrace? or just on the outer skin and the inner brace would always show an antenna hole????
No radio ordered question [Re: domingo] #2711634
10/31/19 02:22 PM
10/31/19 02:22 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
E bodies with no radio ordered had a rubber plug in the body behind the kick panel where the antenna lead would have gone if the car had been ordered with a radio.
No radio ordered - no antenna so no hole for one in the top of the fender or in the brace on the underside.
Re: No radio ordered question [Re: Alaskan_TA] #2711680
10/31/19 05:59 PM
10/31/19 05:59 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
gotcha! thanks!
Re: There is no such thing as radio delete. [Re: A12] #2711707
10/31/19 07:25 PM
10/31/19 07:25 PM
new haven ct
K
kcarfanatic Offline
kcarfanatic  Offline
K
new haven ct
............. Sorry just my posi-traction, build sheet, data tag rant but I know there are some good arguments for this "delete" term so fire away......
You forgot Z bar,aka torque shaft
Re: No radio ordered question [Re: Alaskan_TA] #2711806
11/01/19 09:52 AM
11/01/19 09:52 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
My 66 Belvedere has “radio delete”. When I purchased it there was an antenna and a gapping hole in the dash that was peeled back. After taking the fender off I could see someone had used a punch to make a hole (in the hinge box) small enough to get the cable through, there was no other hole in the normal place so proof car came without radio. When I worked at the dealer I had to drill the holes (both) if a customer wanted a radio installed. Normally radio was ordered for the particular car and came as a package kit, template included.
Btw, my 4 door car has no radio, I’m using the fender and the plate. Looking down through the windshield in the speaker grill (wondering what was used) I see no tape or blocker of light, maybe rats ate it?
Re: No radio ordered question [Re: cudaman1969] #2712639
11/04/19 11:45 AM
11/04/19 11:45 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I've owned and seen plenty of radio delete (what we call a car that didn't come with a radio) Mopars. I've never seen a plug in a fender. If the car didn't come with a radio it doesn't have a hole in the fender.
2011 Drag Pak Challenger
Re: No radio ordered question [Re: rickseeman] #2713451
11/06/19 06:24 PM
11/06/19 06:24 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I`m pretty sure the later 70`s A bodies had the chrome plug in the fenders IIRC. https://bluestarperformance.com/antenna-hole-plug-3501331-b-c-f-m-r-body-1974-83-nos.html
Re: No radio ordered question [Re: mopars4ever] #2713534
11/06/19 10:17 PM
11/06/19 10:17 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Yup !!! Mom & Dad bought a 76 Valiant 4dr, slant 6, auto with power steering, heater, no other options. brand new !! The fender had that plug in it !! I still have that to this day, after putting aftermarket radio and antenna on the car !
Re: No radio ordered question [Re: a12rag] #2713598
11/07/19 09:48 AM
11/07/19 09:48 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
After 71, the factory really started trying to standardize things and cut costs. It wouldn't surprise me that they started adding a plug instead of having separate fenders. It makes the build process easier if you just have one part to pull.
