Hemi oil pan #433197
08/09/09 10:26 PM
08/09/09 10:26 PM
gulfport, ms, west mi
rowin4 Offline OP
rowin4  Offline OP
The reproducion Big block- Hemi oil pans claim 6 qt.'s Is it an actual 6 or are they counting the filter. Also does anybody know the depth of the pan? and will it fit a A-body car?
Re: Hemi oil pan [Re: rowin4] #433198
08/09/09 11:16 PM
08/09/09 11:16 PM
If your asking about the 197-71 Hemi, 440 6 pak I use it It does hold 6 quarts in the sump plus one in the filter. That pan will hit the stock A body K member if you mount the motor in the stock location in relation to the trans mount. My motor is mounted one inch back in relation to the trans mount The idler arm does rub the oil pan on a hard right turn.
Re: Hemi oil pan [Re: Cab_Burge] #433199
08/09/09 11:20 PM
08/09/09 11:20 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
With 5 qts in the pan and 1 in the filter, my OEM 440 dipstick shows "full" w/ my repro Hemi pan, so that's as much as I've ever run in it.
Re: Hemi oil pan [Re: Cab_Burge] #433200
08/09/09 11:21 PM
08/09/09 11:21 PM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
Ran one when we first put the car together and as stated above it does hit the K-member on the passenger side. I gave it a couple of smacks with a hammer and cured it.. and yes it holds 6 + filter.
Re: Hemi oil pan [Re: 70dusterjohn] #433201
08/09/09 11:35 PM
08/09/09 11:35 PM
rowin4 Offline OP
rowin4  Offline OP
Thanks for the replies , does anyone have the depth of the pan?
Re: Hemi oil pan [Re: rowin4] #433202
08/09/09 11:38 PM
08/09/09 11:38 PM
Deerfield, Ohio
Deerfield, Ohio
I could get it for ya in the morning unless someone else has it handy..
