Re: Engine Builder Experience????
[Re: BLONDE BARRACUDA]
#432592
08/09/09 07:53 PM
08/09/09 07:53 PM
Posts: 3,397 Pa
Hot 340
Pa
From March on, the guy got a call EVERY monday until I picked up the engine in June....
The timeline should be the last of your worries, everybody gets behind once in a while, your build prolly has bigger issues.
#432593
08/09/09 08:08 PM
08/09/09 08:08 PM
Posts: 644 Minnesota
Barnstorm
Minnesota
I used to have an engine builder that I would keep a candle in his shop and used to hold Candle Light Vigils until my stuff was done. Helped a little. My guys dyno everything. You always find stupid, minor leaks etc. Plus if the motor is a pooch, you can [Edited by Moparts - Family Friendly Site - Keep it clean]!
The little old lady from Pasadena is back!
#432594
08/09/09 08:40 PM
08/09/09 08:40 PM
Posts: 611 Boise
Moparteacher
Boise
Find another builder! First off, if he can't deliver it on time then he's not a professional.
Lash should have been set, checked, and re-checked! Period!
Finish on heads and block should have been suitable for the gasket chosen, whether it was chosen by him or you.
This "I can't guarantee cometic gaskets" is a cop-out and a lame excuse for inferior workmanship, and a failure to pay attention to details.
The bolt on the balancer should have been installed, properly torqued, and secured with lock-tite.
This guy is no engine builder. He's a bolt-it together-er.
Now, if it helps, I always fire my engines up without water and coolant, bring up to operating temp, and shut-down and allow to completely cool. If it has aluminum heads I then retorque.
[Re: Moparteacher]
#432596
08/09/09 09:19 PM
08/09/09 09:19 PM
Posts: 3,695 nc
emarine01
nc
I would try the bars seal, re torque head,set lash and basic tune, swap oil filters and cut up the first filter and inspect, if it does not scare you, put a new filter on & run some time on it with no load , check oil temps and inspect another oil filter , the 2nd one should be clean or real close to it, if its full of bearing or metal I would contact the shop that built it.
