Page 5 of 12 1 2 3 4 5 6 7 11 12
Re: SB stroker options for track car [Re: AndyF] #432286
02/10/10 01:58 PM
02/10/10 01:58 PM
Manitoba, Canada
O
Overdrive440 Offline
O
Manitoba, Canada
Any update on the Quicktime bellhousing starter nose support issue?
Re: SB stroker options for track car [Re: Overdrive440] #432287
02/10/10 02:08 PM
02/10/10 02:08 PM
AndyF Offline OP
AndyF  Offline OP
Just going to run the nose unsupported and see what happens.
Re: SB stroker options for track car [Re: AndyF] #432288
02/10/10 05:14 PM
02/10/10 05:14 PM
AndyF Offline OP
AndyF  Offline OP
The Comp rocker arms measure about 1.47 effective ratio on these heads which isn't bad. I like the oiling setup on the Comps with a hole that shoots oil right at the roller tip.
Re: SB stroker options for track car [Re: AndyF] #432289
02/10/10 06:15 PM
02/10/10 06:15 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
I have ran a Lakewood scatter shield with JW 'wheel' and Bert trans in dirt cars with the Mopar mini starter and no nose support with very few problems. The engine was 408" w/12:1 CR. To mount/align the starter with the 'wheel', I had to make a shim plate to put between the starter and mount surface of the bell housing. On an occasion or two, we would have to re-position and re-tighten the starter as it would move a little and not engage smoothly after several hundred laps. Not a huge problem, but not 100% fail safe.
If you like drag racing, support your local track.
Re: SB stroker options for track car [Re: AndyF] #432290
02/11/10 10:58 AM
02/11/10 10:58 AM
Lansing, MI
MuscleMike Offline
MuscleMike  Offline
Lansing, MI
Why no chain tensioner? The chains on SB are so long they seem to get sloppy real easy. MP part #P5007709.
Mike @MM
Re: SB stroker options for track car [Re: MuscleMike] #432291
02/11/10 12:23 PM
02/11/10 12:23 PM
AndyF Offline OP
AndyF  Offline OP
The last chain tensioner didn't last very long so this time we'll run it without one.
Re: SB stroker options for track car [Re: AndyF] #432292
02/11/10 02:43 PM
02/11/10 02:43 PM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
Any ideas why/what it failed? Is this a possiblity for the aftermarket?
Re: SB stroker options for track car [Re: AndyF] #432293
02/11/10 05:14 PM
02/11/10 05:14 PM
AndyF Offline OP
AndyF  Offline OP
I got a set of RAS rocker arms to try on this motor. Very nice parts, just like their big block rocker arms. Heavy duty hold downs, bronze bushings, stainless investment cast parts, etc.
Re: SB stroker options for track car [Re: AndyF] #432294
02/11/10 05:16 PM
02/11/10 05:16 PM
AndyF Offline OP
AndyF  Offline OP
Also tried a set of PRW rocker arms. These rocker arms come fully polished which is kind of unique. They are similiar to the Comps but have a bushing and a little different oiling setup. The PRW rocker arms come complete with hold down hardware while the Comp setup is just the rocker arms and the shafts. I went with the hold down kit from Hughes to install the Comps which adds another $85 to the system.
Re: SB stroker options for track car [Re: autoxcuda] #432295
02/12/10 01:38 AM
02/12/10 01:38 AM
auto-xr Offline
auto-xr  Offline
autoxcuda,
Roller timing chain really cut into the tensioner in no time. Yes, that engine was run hard and HOT but oil pressure was always present. Maybe its meant only for factory link style chains??
68 Valiant- was auto-x now track day car
Re: SB stroker options for track car [Re: auto-xr] #432296
02/12/10 02:23 AM
02/12/10 02:23 AM
So Cal
So Cal
autoxcuda,
Yea, that situation you had shouldn't have really affected the chain.
You've got a point than a non roller chain has a lot more surface area and smoother on it's backside that rubs the tensions than a roller chain.
Re: SB stroker options for track car [Re: autoxcuda] #432297
02/14/10 02:58 AM
02/14/10 02:58 AM
AndyF Offline OP
AndyF  Offline OP
Here is a picture of the tensioner after just a few hours of operation. This part was failing quickly. The chain was eating grooves into the plastic pad and dumping plastic chips into the motor. In a little while it would've been eating into the spring.
Re: SB stroker options for track car [Re: AndyF] #432298
02/14/10 03:00 AM
02/14/10 03:00 AM
AndyF Offline OP
AndyF  Offline OP
Picture of the RAS rocker arms. These are 1.60 ratio with bronze bushings and oiling to the roller tip. Very nice parts.
Re: SB stroker options for track car [Re: AndyF] #432299
02/14/10 03:10 AM
02/14/10 03:10 AM
Renton Washington
Triple Threat Offline
Renton Washington
I read this thread back in the beginning, didn't realize there was this much info here now.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: SB stroker options for track car [Re: Triple Threat] #432300
02/14/10 12:13 PM
02/14/10 12:13 PM
SoCal
Brian Hafliger Offline
SoCal
I've seen similar results with the tensioners others have brought to me...I will never use one EVER!!
Brian Hafliger
Re: SB stroker options for track car [Re: AndyF] #432301
02/14/10 01:03 PM
02/14/10 01:03 PM
Pacifica, CA
Devilbrad Offline
Devilbrad  Offline
Pacifica, CA
This build is perfect for my D100! Do those new Comp roller lifters require bronze bushings? What bearing clearances are you running? Any block oiling modifications? Decided on an oil pump yet? Sorry for all the questions, LOL
Re: SB stroker options for track car [Re: RyanJ] #432302
02/18/10 01:07 AM
02/18/10 01:07 AM
AndyF Offline OP
AndyF  Offline OP
BLP (Bo Laws) makes steel AN 3/8" to -10 & -12 like you were looking for.... About 4.4" long.
I've never been comfortable going down to -8's.
I got the fittings from BLP. Nice quality stuff, thanks for the tip.
Re: SB stroker options for track car [Re: AndyF] #432303
02/18/10 01:07 AM
02/18/10 01:07 AM
AndyF Offline OP
AndyF  Offline OP
On the engine
Re: SB stroker options for track car [Re: AndyF] #432304
02/18/10 05:46 AM
02/18/10 05:46 AM
New Zealand
dart6 Offline
dart6  Offline
New Zealand
Hi Andy did you use the 12 an and what are the allen screws on sides for
thanks
Re: SB stroker options for track car [Re: dart6] #432305
02/18/10 12:07 PM
02/18/10 12:07 PM
AndyF Offline OP
AndyF  Offline OP
Yes, I'll use #12 AN on the dyno but I think that car is plumbed for #10.
I don't know what the set screws are for, maybe a place to hang a oil pressure gauge or maybe a handy place to plumb in the valve spring oilers or something.
